Question about HP LaserJet P1505n Printer
P1505 clicks a few times before printing a page
Well, the printer when cold seem to print a page ok. However after a few pages, it goes thru the motion (makes some initialization noises 3 or 4) of wanting to start but it does not click to pick up the paper, eventually it clicks and picks up the paper and prints... any help is appreciated
Posted by Bahman Farzad on
Brandan Heasley
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
It needs serviced
Posted on May 31, 2019
5 Related Answers
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: HP 2430 jams from optional tray 3 only.
Hi Rich,
I've had this problem too. I believe it's the post that holds the drive gears wears or becomes loose causing timing problems.. Unfortunately there's no spare parts available for the optional tray. You would have to purchase a whole optional tray.
Posted on Mar 12, 2009
Anonymous
SOURCE: Hp 2115 - clicking noise from carriage, can`t print test page
I have an HP 6110 is always has a grinding noise.No functions work. HP just want me to buy a new machine. They are bad quality 3 in one's. That is for sure.
Posted on Jul 23, 2009
SOURCE: HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Posted on Aug 31, 2009
SmartFix
SmartFix
  • 89 Answers
SOURCE: HP Laser Jet 1100 - Pulling Multiple Pages thru when printing
Just by Cleaning and changing the Pickup roller
Click here and Follow the steps.
Please rate my response!!!
Posted on Jan 29, 2010
adi
  • 526 Answers
SOURCE: The laser makes a grinding
The most common issue is the fuser. Either the gear is broken on the fuser, or the bushing is worn out.
I recommend you take the unit in for service.
Posted on May 28, 2010
Printer will not print queque HP Laser Jet P1505
first remove the power and usb pin from the printer wait for few minutes then connect them back into the socket then click printer icon in the task bar and open it and remove all the contents then again remove the power and the usb of the printer and restart your computer then connect the power plug and the usb into the printer then click start settings printer and make your printer default then right click your default printer and select properties in the printer properties click print a test page
Apr 01, 2011 | HP LaserJet P1505n Printer
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
Printer prints a page then sends thru a blank page... prints page then blank page...
I posted this video a long time ago...hope it helps!
utube.png You-Tube video "WrxT2_T6JVA" placeholder (do not delete) utube.png
Good Luck!
Jan 02, 2010 | HP Photosmart C7280 Printer
Windows Home Basic 32 bit and HPC4380 printer setup wirelessly. Have printed ok in the past but now get blank or incomplete pages. Have installed latest Aug 2009 driver and have re-installed many times....
To isolate the exact cause of this issue please print a self test page and check whether the same issuse persists.
Print Self test page:
Please click here and follow the instructions to print a self test page.
If test page is not printed properly then clean cartridge contacts and nozzles.
If issue still persists then replace the cartridges.
Sep 05, 2009 | HP Office Equipment & Supplies
How can i print the front and the back of my paper at once for lexmark x5470
When you want to print both sides of a page, when you go into the 'Print' command click on 'Properties' and another windows opens. Select 'Print Layou' and you will see a box marked 'Two-Sided' - click this box. The other option is if you want to flip from the top or turn from the side, like a book. Select which way (I use side flip) and click OK, which brings back to the start and click OK to print. Once the pages have printed you will still need to rotate the pages and place them back in the printer; there will be an instruction page printed halfway thru to show you which way to place the balance of the pages in the printer.
Might sound tuff, but once you've done it a coupla times, you won't even need to print the halfway intrsuction sheet. Good luck. Cheers.
Aug 05, 2009 | Lexmark X5470 All-In-One InkJet Printer
Don't want job page to print every time we print
you can turn off print summary by accessing printer menu , one of the function
Mar 21, 2009 | HP LaserJet 4350 Printer
Printer keeps saying change paper size
Go to Control Panel - Printers and on MF3310 right click and choose Default settings. I had to change page size from Letter to A4 and output size from Match page size to A4 as well. Finally, after 4 hours of investigations it worked.
Jan 30, 2007 | Canon MF3110 All-In-One Laser Printer
HP LaserJet P1505n Printer Logo
61 people viewed this question
Ekse
efs_perpends
efs_perpends
