Dogs Logo
Question about American Plastic Toys Dogs
Can I replace the batteries in the babble ball?
  • Bill Irwin
    Bill Irwin Sep 12, 2018
    I have removed the 2 deep Phillips head screws, the problem is removing the plastic plug. I've tried using various sized flat-blade screwdrivers with no success. The plastic just deforms without any movement. Did you use a hook of some kind? How to remove this plastic plug?
Anonymous
    New Friend:
  • 22 Answers
The battery compartment can be opened by removing the 2 deep set Phillips screws. Replace with 3 new 1.5 volt batteries and you can find the batteries in your local store.
Posted on Sep 02, 2012
Lucia Chambers
These answers have ZERO relevance to the question. Throwing out the toy is the only solution.
Posted on Jun 23, 2021
2helpful
2answers
The 1.5 batteries I bought are too thin and I can't find any the same thickness as what is in the babble ball
The batteries you bought are not an exact replacement. What is the number stamped on the original battery? Buy batteries with the same number. If they are a different brand, google "(insert original #) equivalent" and it should give you information on correct batteries of different brands to buy.
Feb 09, 2018 • Toys
My babble ball didn't work after I pulled out the plastic strip, what should I do?
Sometimes the batteries don't pop into position when the strip is removed. You should tap the ball on a hard surface and it will usually do the trick.
Is there a way to deactivate the babble ball?
Absolutely, simply slide the plastic strip back into the battery slot and between the batteries.
Do the babble balls have warranty?
The babble balls are guaranteed to be free of defects and most companies will give you a new ball I case it has any defect. The babble balls have no warranty over chewing damage, abuse or warn out batteries.
How should I clean the babble ball?
You should use a clean damp cloth with and gently wash the dirt and saliva off the ball's surface. Don't submerse the ball as it will damage the electronic components of the ball.
How would I know if the babble ball is right for my dog?
The babble ball appeal most dogs that like to play and run. Some timid dogs may be initially cautious nut curiosity usually wins over quickly.
How durable is the babble ball?
The babble balls contain electronic components and are intended as an indoor toy. The ball won't be damaged by chewing or hitting walls but it is not designed to be hit with baseball bats or tennis rackets.
For how long the battery usually last in a babble ball?
Depending on your dog play habits it will last more or less. For instance if your dog causes the ball to make 100 sounds per day, it should last for approximately 4 to 6 months.
What size of babble ball is best for my dog?
The Small Babble Ball is intended for the tiny breeds up to 10 pounds. The Medium Babble Ball is for dogs 12 to 25 pounds and the Large Babble Ball is for the large breeds above 25 pounds.
What makes the babble balls so appealing?
The babble ball combines features that every dog loves, ball shaped toys and noisy toys. The more your dog plays with the ball the more he will like it.
Top American Plastic Toys Dogs Experts
sharon perry
sharon perry
Level 1 Expert
Are you an American Plastic Toys Dog Expert? Answer questions, earn points and help others
