Question about Thermador 37 in. CEP365 Electric Cooktop
I need a replacement glass top for my Thermador CEP 365/CET365 cooktop. It is cracked but works fine. Where can I get this?
I cracked the glass top while using the pressure cooker and want to replace it for my landlord before I move out. It works fine, just the edge is cracked. If it is too old to replace, just knowing the value that I can pay her so she can apply it to a new stovetop once this one is used up would be very helpful.
Posted by lori gregory on
Bill Boyd
    Top Expert:
  • Thermador Master
  • 53,816 Answers
Contact the service agent for the brand to see if a replacement glass is available
in reality you are not required to replace the glass as glass breaks in normal use and is out of your control and in renters terms comes under fair wear and tear
Posted on Dec 21, 2017
1 Related Answer
gerbee gomez
  • 222 Answers
SOURCE: TRYING TO REPLACE THERMADOR CERAMIC TOP OF COOKTOP
much beter to call an technician coz the glass ceramic is no warnaty,if u get wrong instalation or broke the glass u waste ur money,call the person have an expertise for that.dont try to fix by it ur self.coz if the technician fix it,u get an assurance for the waranty if may happen during instalation.
Posted on Sep 13, 2009
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
Glass top is cracked on my Radiant Cartridge, however the unit works fine. Can I replace the glass top?
In most cases, yes. You did not provide a model number so we were not able to check availability for your particular unit.
Oct 24, 2009 | Cooktops
How to repair cracked corner of black ceramic cooktop
Epoxy would not work. If it is a very small chip and is NOT STRUCTURAL or in the heated are you could TRY the adhesive used for rear view mirror to glass attachment.
Sep 13, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Roden Gas glass stovetop shattered MODEL GC73H
I have come across this occurence twice before.
With glass stove tops the glass is toughened and can generally withstand most temperatures associated with normal cooking situations. This, of course, assumes that there is sufficient space beneath the cooking utensil (saucepan, frying pan, etc) for air to circulate and the build up of heat to dissipate. If this cannot take place heat will build up to the point that the glass - a refractory material will no longer be able to withstand the internal and external forces created by the differences in internal and external temperatures and will thus shatter.
Though this is generally rare, it is known to take place and users are warned. Incidentally, this is the reason the shape of the glass top is the way it is and not the usual square as with other tops, in order for the heat to dissipate more easily.
In short, you should insist to your landlord that you were not misusing the appliance, but through genuine use this somewhat rare event occurred.
Aug 06, 2009 | Cooktops
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cracked Glass Top
I not know of any means of repairing same (maybe the system used to fuse auto glass) but if you want to replace it try repairclinic.com Item 935927 or 948440 $216/$227
Aug 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Broken glass cook top
The top can not be repaired. The glass must be replaced . DO NOT USE IT CRACKED!!!!!!!!!!!! This is very dangerous as it can explode from the temperature. Also this is a severe electrical danger as glass top units have exposed elements underneath. Any liquid at all can short it out and cause a fire. I don't know if it is worth repairing. I don't have the exact price for your cooktop but last one I priced was between $350 - $500.
Jun 26, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Glass cooktop keeps cracking in same area
The cooktop box has a metal flange. Make sure the cooktop when dropped into the countertop is resting on ther metal flange and not the glass edge by itself. If it rests on the glass alone the weight will cause the glass to crack at some point in time.
Dec 20, 2007 | Cooktops
Thermador 37 in. CEP365 Electric Cooktop Logo
470 people viewed this question
Top Thermador Cooktops Experts
Michael Thomas
Michael Thomas
Eric Gundersen
Level 1 Expert
Jorgie Navito
Jorgie Navito
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
