Question about Samsung BN59-00852A Remote Control
Onkyo Codes for Samsung remotes?
Does anyone know the codes Samsung uses for Onkyo?
  • 226 Answers
Hi, unfortunately this remote does not have the ability to program to your Onkyo receiver. You must use your original Onkyo remote to control the volume of it. If you need a new Onkyo remote you can purchase one from Replacement Remotes. You can also buy a universal remote to program and work for both your units, so you will not have to keep switching back in forth between remotes. If you would like a universal I suggest getting the RFS200, this remote will even work if your receiver is not in direct line of site.
Posted on Oct 09, 2012
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Samsung Remote code
Hi Friend
My Samsung TV Model is : CS21S67WX/XTML
Serial No is: 0151-32ARC00985Y
I need to use ir remote through my phone so May i know the remote code for this model pls send me a reply at: [email protected]
Basha
Posted on Mar 14, 2008
Want to know how to set up my bell expressvu remote to control my onkyo tx-sr605 receiver?
If you are trying to use another manufactures remote to control your Onkyo receiver they are the ones who are responsible for programming the Hexadecimal codes into their remotes. We do not have codes for any other manufactures remotes. You may want to try the following website for codes www.remotes.com or http://www.remotecodelist.com for any codes to program your remote. As we do not have the remote controller codes for non-Onkyo controllers- you can try the generic remote controller code: 62503 or 52503.
May 04, 2014 | Onkyo TX-SR605 Receiver
Have Onkyo remote trying to program by Samsung
The Samsung DVD codes for Onkyo remotes are: 30490, 30573, 30820, 31075, 31635, 32329, 32489, & 33001.
You can download Onkyo remote codes here.
I hope that helps.
Mar 27, 2010 | Samsung DVD-HD870 DVD Player
Onkyo remote won't control Samsung components.
I got an Onkyo RC-717M remote control. It is the remote that comes with the Onkyo TX-SR706 receiver. It is a learning remote. When i entered the cde for the Samsung Blu-Ray it did the same thing as the other remotes I got from Onkyo, the pause, next / previous track buttons wouldn't work for the Samsung BD-P3600. I used the learning function of the new remote and programmed it to work. It works ok now but it sure was a hassle to get it done. In fairness i should have called Onkyo support but their support hours don't match my schedule.
Sep 12, 2009 | Onkyo TX-SR606 Receiver
Need Onkyo SR803 Remote code for Samsung BD-P1590
This should help you.
http://codesforuniversalremotes.com/samsung-blu-ray-player-remote-control-codes/
Dec 02, 2017 | Onkyo TX-SR705 Receiver
Using An Onkyo Remote to control Sky+
Code that I have for sky + is: 01175. There are several other codes for other versions of sky boxes if you think you may need them but that should be the one.
Samsung has a huge code list: 10017, 10037, 10047, 10054, 10056, 10060, 10090, 10092, 10093, 10154, 10156, 10178, 10226, 10702, 10766, 10814, 11060, 11235. Unfortunatly you'll just have to try them one at a time until you find one that works. Hope this helps.
Jan 07, 2009 | Onkyo HT-S780 System
Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Jun 14, 2008 | Onkyo TX-DS787 Receiver
Code for Sony BDP-S300 Blu-ray player on Onkyo remote
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
Feb 21, 2008 | Onkyo TX-SR605 Receiver
Code for Verizon FIOS remote Control
I have a solution which has worked well for me. It uses the DVD button at the top of the remote. It was a trade-off as none of the codes in the RC144 Philips remote will work any Blu-ray players, so the DVD button was unassigned. The 922, 955 and 977 codes are explained in the directions for the FIOS remote. http://onlinehelp.verizon.net/consumer/bin/pdf/philips%20rc1445302%20user%20guide.pdf
1. Set up your TV button to work your TV.
2. Set up your Onkyo code, pick one to turn on the receiver. I used 3719
3. Use the 9-2-2 code to cycle through all available codes. At about a count of 300 I found one which will turn the Onkyo receiver off. Make sure you start this process with the ONKYO receiver already on. Once you find it press the OK button.
4. Use the 9-7-7 code to power all devices TV, AUX and DVD from the power button.
In this way, each time the power button is pressed it will send both the power on and power off signal to the ONKYO receiver.
This technique works well when you point the remote at the ONKYO receiver and press power button. Apparently the TV has better reception for the signal then the ONKYO does.
Oct 24, 2007 | Onkyo TX-SR605 Receiver
Samsung BN59-00852A Remote Control Logo
338 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
