Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp ar 5516 maintenance reset
Sharp ar 5316 maintenance reset
Posted by sofein on
intelsrinu
    New Friend:
Sharp ar 5516 showing ( - - - ) what's the solution
Posted on Apr 18, 2013
  • nunmoia Sep 12, 2018
    me too me too me too me too
Sanjiv Dutta
    New Friend:
I want SHARP AR- 5516 DEVELOPER AND SERVICEMAN RESET CODE PLEASE HELP ME.
Posted on Jun 20, 2014
  • Monirul Islam
    Monirul Islam Feb 25, 2017
    sharp ar 5516 error code 7, 3
Everett Lin
    President:
  • Sharp Master
  • 990 Answers
Hi sir; press 4-key as follow by order "#, interrupt,C, interrupt " then enter 20 then01, repeat 4-key again then enter26, then enter 36 press1
Posted on Sep 02, 2012
  • 1 more comment
  • Mohammad ?i???
    Mohammad ?i??? Dec 02, 2014
    I apply this methos but not result
  • Mohammad ?i???
    plzzz tell me I have same problem
  • Amran Hossain
    Amran Hossain Mar 20, 2017
    # int C int 42 start 1Start.
Mohammad ?i???
    Habit-Forming:
    New Friend:
I have problem in sharp 5516 (---) what salution plz tell me
Posted on Dec 02, 2014
haideralsandok
    New Friend:
Hilp me
sharp ar 5516
sharp ar 5516 maintenance reset - sharp-ar-5516-maintenance-reset-ws1sl0ws24t5ie2pv5maawsl-1-0.jpg
Posted on Oct 13, 2015
  • 4 more comments
  • Amran Hossain
    #Int C int when display is off press 20 Start 1start
    #int C int 42 start 1 start.
  • Mohamed Safeer
    Mohamed Safeer Apr 19, 2017
    Sharp 5516 coppy not clear loang line coppy light
  • Mohamed Safeer
    Plz helpe me
  • Ks Ketheeswaran
    Ks Ketheeswaran Jan 10, 2018
    Display 02 wat problsm
  • Daramola Richard
    Daramola Richard Mar 07, 2018
    My AR 5516 Is too light and poor printing
    pls solution
  • Rc Sapkota
    Rc Sapkota Jun 06, 2018
    same problems help me
Kalyan Ji
    New Friend:
The scanner is not working what is the solution
Posted on Oct 26, 2013
  • 1 more comment
  • Kalyan Ji
    Kalyan Ji Oct 26, 2013
    still it is not working
  • tonymuga May 26, 2014
    exposure lump, check it and clean or replace
  • mohamed mureeth
    mohamed mureeth Jul 29, 2016
    bypass paper jam what solution
victor ferrao
    New Friend:
Having a ar 5516 giving problem every week sound when paper comes out paper getting stuck
Posted on Apr 04, 2014
  • SalahAddin
    SalahAddin May 04, 2014
    check your fuser gear or unit drum gear
Latif Ghafary
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Hi, help in this please. nothing is work . Sharp 5516d
sharp ar 5516 maintenance reset - 18789562_1336032516492435_1578488147_o-xisx5rbfdvjhgck0ikolxupa-1-0.jpg
Posted on May 29, 2017
Bethel
    New Friend:
    Problem Solver:
  • 5 Answers
Press # interupt c interupt den enter 20 sub 1
Posted on Dec 29, 2018
nirojan nimal
    New Friend:
Hi i have a 5516 sharp photocopier printer is worked but photocopier not work pls help me
Posted on Sep 27, 2015
5 Related Answers
Anthony Karuku
  • 268 Answers
SOURCE: reset counter of sharp ar-5316
How to reset meter reading counter;
a. in the operation panel ,press * ,interrupt, CA, interrupt keys.Display must go off.
b. enter 84 and press copy key. 000,000 will flash in the display
The copier meter reading is now reset to 0.
Posted on Mar 20, 2010
Anthony Karuku
  • 268 Answers
SOURCE: I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Posted on Dec 01, 2009
Chuck Clark
  • 33 Answers
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Posted on Jan 02, 2008
Anonymous
SOURCE: I Want Printer driver for AR-5316
http://www.sharp.co.za/techweb/drivers/copierdrivers/gdidrivers/gdidrivers_5316-5320.htm
welcome to pattaya thailand
Posted on Apr 15, 2008
Anonymous
SOURCE: Sharp AR-5316 printer drivers for windows Vista
want to find your driver for sharp ar-5316 for windows vista,you just go to this website http://support.sharp.net.au/drivers/ and u good to go....:)
Posted on Feb 02, 2009
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
Reset counter sharp ar-5631
Press the :
( #/P ) key --> ( * ) key --> ( clear ) key --> ( * ) key
clear the misfeed: 24 start --> 1 start
reset the maintenance counter: 24 start --> 4 start
reset the developer counter: 24 start --> 5 start
reset the copy counter: 24 start --> 6 start
reset the printer counter: 24 start --> 9 start
Nov 03, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
We are trying to connect the Desk top PC so as to use AR=5316 as a printer.Need help to install the printer software. Can I get it downloaded from Sharp site. Please reply.
you may gey the driver software for AR=5316 printer install sotware inthese websites
http://nodevice.in/driver/AR-5316/get47086.html
http://ptf.com/sharp/sharp+ar+5316+printer+drivers+to+support+windos+7/
Apr 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
How can install the sharp ar-5316 black and white cartridge
Hello sir; you have to open the side door first and then open front door , then slide out TD cartridge and drum cartridge, it will automatic reset.
Jul 11, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Oct 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M165, maintenance led and developer replacement leds on
It's the drum thats causing the lines to happen. Youre going to have to get that replaced before you can reset the counters.
If you get light copies, then the developer should be replaced.
Sep 01, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
13,038 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
