To use scroll function, you have to install the touchpad drivers, which are available from Toshiba Official Support. Click Here to download the required touchpad drivers. Select 'Touchpad' from Category and install Synaptics or Alps Drivers (Depending upon the type of touchpad you have on your system).
just reinstall the driver for it ..if it has no driver it works just with the generic one in windows and the scroll and select will not be allowed..or install a usb mouse and will be easier to work and have all features..(in case the driver is not available for the touch pad ) here is the place to look for the pad's driver .. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=380609&rpn=PS630U&modelFilter=&selCategory=2756709&selFamily=1073768667 this is for Toshiba m-15 s405 ...I linked it cause you placed the question in this category ..If you use another model ..select it from the download list ..also select the operation system .. If you do use this one ..but another operation system try to install it anyway but under the executable properties modify to run in compatibility with windows xp have a nice day ..and please rate my answer ...
try to check your touch pad without AC power i mean run your computer on battery if your touchpad working ok on battery so there is a problem with your adapter ampere ask any local repairing center to check your adapter ampere or change your adapter and do not purchase compatible adapter, compatible adapter can not resolve your touch pad problem go for original adapter from toshiba
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
