I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
What's the model? Do you have the stitch selector set on straight stitch, or on a stitch with a width component, like a blind hem stitch?
Some machines consider straight stitch to be a zigzag stitch of width=0, while others have separate settings for a straight stitch and a zigzag (or other) stitch.
Tension knob on any machine will be in the thread path and usually above the needle somewhere, while the stitch width and length knobs are usually on the right side of the machine. I cant identify your model but on any machine straight stitch is usually a length of 2.5 and width of 0, while a zigzag the width will be set somewhere between 2-4 depending on how wide you need it to be. There is usually a stitch selector of some sort too but many machines, providing the width is set to 0, you will get a straight stitch.
The knob with dot and F & R should be set to the dot. Thw slider should be at the white dot not the red dot. Red dot does forward only. The rotary knob with WWW O === is the stitch selector. This is the setting for straight and zigzag stitching
Stitch length control any number from 0.5 to 4 Stitch width control any number from 0 to 4 Special stitch modifier; Red dot Buttonhole control; RED dot
You have 3 knobs/dials on the machine, the top left dials the stitch, the top right sets the length and the bottom right set your width. set it 0 for straight.
It's just in the front panel, where the drawing of all the built in stitches are, it's the drawing number eleven from the left, you'll see a zig zag (red) and a straight stitch (black) Select A group of stitches (knob with the arrow) and then select the eleventh stitch (same knob but use the dial, look the manual) and then select zero on your stitch width dial. Hope that helps :)
