Question about University Games Five Little Monkeys Game
Five little monkey's can't catch me instructions
1 Related Answer
derik purlee
  • 110 Answers
SOURCE: i need the instructions for
Where to begin? How about the board design and its effect on the game objectives. The game requires the completion of two conditions for a win: you must have collected four separate tokens and placed four plastic monkeys on top of the large bed in the center of the board. You accomplish this by spinning a dial on a cardboard wheel and advancing 1-6 spaces along a rectangular track, landing on either an image featuring one of the four tokens or a "monkey space" which allows you to place 1-3 monkeys on the bed. There are a couple of issues here - the board is designed in such a way that, with one or two exceptions, you will always land on the same space every time you spin a '5.' In other words, if you just collected the "teeth brushing" token, spinning a '5' on your next turn will bring you to the next "teeth brushing" token on the board. If you spin another 5 on the following turn, the same thing will happen...and so on and so forth. This doesn't sound like too big of a problem, until someone spins '5' four times in a row, effectively missing three consecutive turns, as advancement in and of itself doesn't really achieve much.
This is further compounded by the fact that monkeys can be knocked off the bed, in a manner similar to some other classic games. At the end of each player's turn, that player must press a button on the bed, and every few turns the mattress will bounce up, knocking a few monkeys back off the bed. This can be very frustrating under the right conditions, and can greatly extend the length of the game if it manages to keep victory out of reach that much longer for all players. It gets worse the more players you add to the game (up to a maximum of 4). It isn't much fun for anyone when a player spins 5 a couple of times in a row and then proceeds to knock all of his or her own monkeys off the bed (happens more often than you might think).
Perhaps the worst part of the game for younger players is keeping them on track throughout their turn. Most games for very young children are set up so that a turn has two steps...three at most. Generally speaking, you roll something or spin something, and then either move your piece and react to that movement or simply react to the result of the spin/roll. In Five Little Monkeys, the child must spin the wheel, move the monkey, place monkeys on the bed OR collect a token, press the button on the bed, and then collect any of their own monkeys that have fallen if the bed sprang up this turn.
good luck!
Posted on Jan 29, 2011
Having trouble understanding instructions or simplisity pattern 1730 the monkey
www.simplicity.com
1)Write to the company and see if they cannot explain or
2) copy the part you do not understand and have then rewrite it is different words.
3)Write out the pattern(the part that you do not understand) and i will attempt to explain it. (worst possibility)
Mar 31, 2014 | Simplicity Animal Stethoscope Covers...
What are the rules?
Place one monkey for each player on the starting square. The other five monkeys for each player start in front of the players.
  • Place one monkey on the bed at the beginning of your turn. University Games recommends the youngest player start, followed by the next youngest, and so on.
  • Flick the spinner to choose randomly the number of spaces to move. Move your monkey that many spaces on the game board.
  • Perform the indicated action on the game board. The actions include bathing, dressing in pajamas, teeth-brushing and going to bed. Act out the actions similar to charades. Once the action is completed, place the corresponding action token in front of you. If you land on an action space you already have a token for, perform the action and the rest of the steps as usual, but do not take a token.
  • Place one monkey on the bed at the end of your turn. If you landed on a space with a picture of monkeys and a number instead of an action, place the number of monkeys indicated on the bed. If you do not have that many monkeys left, put all your monkeys on the bed.
  • Press the red bedpost to end your turn. Pushing the bedpost not only indicates the end of your turn but it also triggers a random action. Occasionally, the bed will shake. If your monkeys fall off, put them back in front of you. If they fall over but do not fall off the bed, set them up right again.
  • As you move around the game board, if you pass the start square, place another monkey on the bed. Repeat steps 2 through 5 until someone has all four action tokens and a minimum of four monkeys on the bed, winning the game.
  • Aug 11, 2012 | University Games Five Little Monkeys Game
    The thread uderneath is straight. I have an elna. I know left is loosey ad right is tighty, but it doesn't seem to change when adjusted.
    the top tension dial is for the top thread, only monkey with the bobbin screw
    if nessary. always try the top tension first
    do you have a instruction manual for the machine?
    Debbi
    Apr 12, 2012 | Sewing Machines
    Eezy peezy monkey bars instructions on how to pull apart?
    Hi there:
    You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
    Hopefully one of other experts will be able to provide you with a real solution.
    Thank you for using FixYa.
    Jan 05, 2012 | Cars & Trucks
    The grey pre-filter catch broke and we ordered a new one. now we don't know how to install it.
    I just successfully completed this replacement on a DC33 (the prefilter catch is blue on this model.) Not sure how different the assembly is from the DC07 but thought I would post: If you turn the vacuum over there are two screws that loosen the exhaust pipe--one you can see and one up a small shaft (which also loosens the cowling just under the cyclonic assembly.) Both will require a driver or allen-style wrench with a medium-sized star head. Remove both and you will be able to take off the exhaust pipe. You'll need to pull back the aforementioned cowling a bit as you do this. Once the exhaust pipe is off you will be able to see the bottom of the prefilter catch. You'll notice five tiny bays--if you shine a flashlight through you'll see that between bays 2 and 3 there is a small catch (you can note it at the bottom of your replacement prefilter catch as well.) Shove two extra small screw drivers (like the size you get in eyeglass repair kits) into bays 2 & 3, then gently press down on the driver handles to release the catch. A little pushing at the same time will remove your broken prefilter catch. DON'T INSTALL YOUR NEW CATCH YET! Otherwise, like me, you'll have to immediately remove it to reinstall the exhaust pipe :) This was the most time consuming part of the whole operation, as you kind of have to fenangle it a bit to get it back on. Be patient and don't forget to pull the cowling back again while you're doing this. Once it's back on, realign the cowling at the top of the assembly and replace the screws. Then you can turn the vacuum upright again to easily snap in your new prefilter catch.
    Nov 03, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Are there printable instructions?
    unfortunately, there is no way to print out instructions. You could make copies of the instructions, or scan them then print them. I hope that helps
    Sep 17, 2011 | University Games Five Little Monkeys Game
    I need the instructions for five little monkeys
    good luck!
    Jan 23, 2011 | University Games Staying Alive Murder...
    Instructions for 5 little monkeys game - have all the pieces not sure how to play.
    Yohttp://www.universitygames.com/rules/university_games/FiveLittleMonkeys_Rules_01320.pdfu can get a copy of the directions at
    Apr 28, 2009 | University Games Five Little Monkeys Game
    Catching the golden monkey.
    after you stun him get your cat out real fast and scratch him and keep at it unbtil he runs the stun him again and get you cat back out and scratch. keep this up.
    Jan 22, 2009 | Sega The Golden Compass for DS
    Shrimp Instructions?
    Hi brine shrimp are sea monkeys just google see monkey hatching instructions they will be the same. my instructions do not have the information either but my set came with the brine shrimp. you just wont have pouch #1
    http://www.discoverthis.com/sea-monkey-instructions.html
    http://www.discoverthis.com/seamonkeys-hatching-temperature.html
    Good luck we had 4 generations of sea monkeys. When they fie off you can let the water evaporate from your tank and Add new water and the cycle wiil start all over. we are in that process now 4th time...
    Dec 31, 2008 | Vivitar 900x 28-piece Microscope Set
    University Games Five Little Monkeys Game Logo
    732 people viewed this question
    Top University Games Toys Experts
    Marvin
    Marvin
    Tom Chichester
    ray gallant
    Are you an University Games Toy Expert? Answer questions, earn points and help others
