I changed thermostat & flushed heater core. Checked fuses and still no heat.
SOURCE: not getting heat in cab
Is the blower running at all? Also, make sure the main air intake vent is free of obstructions.
Also, a vacuum leak could cause the actuator to not function correctly. I'd check into the vacuum lines if all else fails. I've had too many cars here with heat/air problems due to vacuum loss and the actuators not switching correctly.
SOURCE: heater problem / engine over heating 5.7 hemi 2004
Test for blown head gaskets, combustion gases can be tested at the radiator neck with engine running
SOURCE: no heat coming out of vents
be sure you have no coolant leak and check if you have a blead valve on the engine for the coolant if you do, blead the air out
SOURCE: 1999 ford taurus no heat
Is the blower motor working? If not that is what it is. If it is working then check heater coil out, Could be bad heater coil.
SOURCE: Have no heat. Have replaced heater core,
I don't know your vehicle, but does it have a blower door tucked in where the heater core is? If it DOES and that's broken then it could be the whole problem. It would mean it isn't switching from the A/C side of things to the heat side of them. Hope this helps, good luck! Also, just looked up the proper name for what I'm talking about, it's called a "blend door" and I think your car has one. It's what I would check, again, good luck!
