Hitachi UltraVision 42HDS52 42 in. HD-Ready Plasma Television Logo
michelle m Posted on Sep 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to factory reset 42hds52
We cannot get audio, so were thinking this might help. Any ideas how to get it back to factory settings?
Anonymous
Level 3:
Top Expert:
  • Hitachi Master 14,553 Answers
  • Posted on Sep 02, 2012
Anonymous
Hitachi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715332
Points
48227
A hard reset rarely helps this sort of issue---look to see if speakers are switched on or off and does the unit work with only a DVD connected to one of the sets of AV jacks on the rear of the set.
No sound from subwoofer lg ht554 home cinema.
Did you check all connections? All audio settings? If yes and it didn't help I think better will be call to specialist in this field. I recently bought new home cinema Ugee 1910B and it works perfect. Quality of video and sound is great.
2helpful
3answers
Stuck in standby
You can reset all to factory settings, which may help; unplug power, put back in switch on with power button. Then press together "tape", "CD" and the power button. You may need to reset the clock before it will work. If you need the manual, here is the link; http://pdf.crse.com/manuals/2048589112.pdf check page 26 for the reset if not clear - nothing else in there that seems to be related, but you may find something i missed. Hope this helps :)
NO AUDIO ON FM BUT HAS AUDIO ON CD?,ANY IDEAS?
Restore factory settings. Google "(model no) factory reset". Luck.
Is there a way to reset the radio to factory settings
I don't really think resetting the radio will help. You may want to check all of your speakers and speaker wiring. If you have any shorts and/or grounds it will affect your audio. The beep is coming from inside of the radio itself. If all your speakers and speaker wires check out good, you may have a bad internal output ic.
Tv is on but no sound. Its not muted and volume is turned up
Tries tv and those cables or dishes boxes unplug,replug it back like about an hour later.For those pay boxes to reboot and upgrading it softwares.The tv to do a whole tv set resetting it self back to the factory setting.Than go into the tv Menu Setting to go to the tv Audio Setting.Go down to do a audio resetting again for the Audio Setting to go back to factory setting.These steps will help and have a great chances to get ur tv audio back.
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Sound when out on 36in Digital Lifestyle flat screen. Any idea how to fix it?
Unplug,replug it an hour later,push menu button on the remote go to audio setting go down to reset push it to get back to factory setting,should get audio back after this.
9helpful
3answers
Sony Ericsson K850i Reset to back to factory setting
I'd imagine that you can look through the modes, or have a master reset, Master reset located Options. Then i think it's the one right at the bottom. I think. Hope this has helped.
Nov 17, 2009 • Cell Phones
2answers
I type in 192.168.0.1 and it asks me name and password and i type in alot of different things that i think would work but they don't. i set it up a long time ago at old apartment and i have just moved to...
If you have forgotten the login and password for the DLink router you can reset the router back to the factory defaults.
In general, to reset the D-Link to the Factory Default Settings, please follow these steps:
1. Turn off the router
2. Locate the Reset button on the back of the router.
3. Use a paper clip to press the Reset button and power on.
4. Hold for about 5 seconds (don’t hold too long) and then release. (Or, release when M1 and M2 flash at the same time.)
5. After you have completed the above steps, the router will be reset to the factory default settings
No audio after adjusting service mode settings
Check the audio menu to see what the factory defaults are. It could be that the audio processor is in a mode which turns off the internal speakers. Usually this is accessable from the customer menus. Most models have several choices for the audio processor and without checking I have no idea what the factory setting would be. I would not think that they would ship a unit that way but stranger things have happened. It certainly can't hurt to see where it is set. Certainly if you have sound through an external amp the sound circuits are working up to the built in amplifier. I suppose the internal amplifier could have a problem but it would be 1 in a million that it happened just as you were doing adjustments in the service mode. I think that it would have to be a configuration issue if it worked before. Good luck.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
