SOURCE: trouble code p0134 and p0171
A code P0134 may mean that one or more of the following has happened:
Possible Solutions
The most common fix is to replace the oxygen sensor. But that doesn't rule out the possibility of:
A code P0171 may mean that one or more of the following has happened:
Possible Solutions
Possible solutions include:
SOURCE: 1999 Chevy Venture continuosly overheating
sounds like u might have a blown head gasket is your oil milky colored
SOURCE: No Heat and Overheating in 1999 Chevy Silverado
After replacing the thermostat, you must bleed the air from the cooling system.
To bleed air from the 2.2L and 2.5L engines, remove the plug or sensor
on the top of the thermostat housing. Fill the radiator with coolant
until the coolant comes out the hole. Since the plug is made out of
steel and the thermostat housing is aluminum, it is a good idea to
apply an anti-seizing compound or Teflon® tape on the plug threads
prior to installation. Install the plug and continue to fill the
radiator. This will vent all trapped air from the engine.
Any trapped air in the heating system will have to be displaced by coolant. Once the cooling system is filled, with the radiator cap off, turn of the heater at it's highest setting. Start the engine and allow it to reach operating temp. You should see a drop in the coolant level as the air in the heating system is displaced by coolant. Add coolant to the proper level and replace the radiator cap.
Keep a close eye on the coolant level for at least the next couple of weeks. The cooling system is a "closed" system. Any significant decrease in coolant level indicates a problem.
If you have any questions, let me know.
Please take the time to rate this solution.
Drive safe and be warm.
clarkco
SOURCE: 2000 Chevy Silverado 1500 The heater does not
Had the same thing happen to my truck, the blen door actuator is under the console on passenger side, but the heater core is going to be clogged if you dont have any heat coming through, but a/c works..
