Question about NetGear Computers & Internet
How do i reset my router
I need to reset my router
    Master:
  • NetGear Master
  • 317 Answers
Hello friends
just follow some simple steps
  1. On the back of your router, locate the Restore Factory Settings or Resetbutton.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Resetbutton and wait for your router to reboot.
for more steps visit https://techvaidya.com/reset-netgear-wireless-router/
I hope this help you
Posted on Dec 29, 2018
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
We can provide you with precise assistance regarding netgear router issues. You can also get the support form experts but there, you will have to search for the resolution yourself. By calling us, you don't have to do anything, as we will take care of each and everything. Call us today at our toll-free number 1-833-455-2100
https://www.getcontacthelp.com/netgear
how do i reset my router - img_5b310705650bc-m1mzyp4btbesy0srxoshfffn-2-0.jpg
Posted on Aug 22, 2018
  • 560 Answers
You can reset your Netgear router/wireless router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Feel free to get instant online Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Posted on Oct 12, 2012
  • NetGear Master
  • 32,281 Answers
To RESET the Netgear, power up the Netgear then press and hold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Sep 02, 2012
Need to reset password for belkin54g
Hello.
If you are having trouble logging into the router's setup page and you forgot the password for the router, you need to reset it to default settings, thus if you do that, you need to setup the router again.
To reset the router to default settings, press and hold the reset button on the back panel of the router for 30 seconds. Once the lights are stable you need to setup the router again just like what you did the first time.
Dec 01, 2011 | NetGear RangeMax WPN824 Wireless Router...
How to set netgear router WNDS3400 to factory settings
If you would like to reset the router to default settings then please perform the below steps:
With the help of a paper clip, press the reset button on the back of the router for 20 seconds (please refer to the label on the bottom of the router for reset button location). Release the reset button after 20 seconds and turn off the router. Turn the router on after few seconds.
Please reconfigure the router using its default credentials mentioned on the bottom panel of the unit.
Regards
Anand
Nov 21, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I for the password to my wireless router, how do I obtain another one to access it?
You may need to reset your router to its Factory Default settings. Which will reset the router Username and password to "admin" without quotes.
To reset the router you need to take a thin pin or a pen tip and check the back side of the router for a button named reset. You need to push the button inside to reset it.
Hope this helps. Good Luck.
~SmokinJoe~
Aug 23, 2011 | Linksys Wireless-G Broadband Router
My wireless router number is WRT120N but I dont remember my pin number how can I can a new one
You need to reset your router to factory setting.
The reset process will restore your router's factory default settings. All of the customized settings of the router will then be erased and the router's IP address will be reverted back to 192.168.1.1 if you have changed it.
To perform a hardware reset on your Linksys router, follow these steps:
Resetting the Router Using the Reset Button
IMPORTANT: Before proceeding with the reset, take note of your router's current settings. You might need to check with your Internet Service Provider to get settings.
Press and hold the Reset button at the back of the router for ten seconds. It will reset your router to factory settings.
Apr 11, 2011 | Linksys Wireless-G WRT54G Router
I forgot my password...
The default password for routers usually is admin for the username and admin for password however you may need to unsecure your router to do that you will need to reset the router please remember by resetting the router will reset to default settings simply press and hold the reset button on the back of the router for 15 seconds or until router resets, you will want to secure your router after. Now depending on which router you have whether its linksys, Belkin, or another router you can go to the main website to show you step by step how to secure your router. Good Luck
Feb 19, 2011 | Computers & Internet
Need to reset router
Hi Friend, In order to reset the router, you will find a small pin point hole on the back of the router. Take a paper clip or a pen and press and hold the red color reset button in that hole for 30 seconds and the router will be reset.
NOTE: Resetting the router, all the settings on the router that has been made for the LAN and the wireless will be lost and the router needs to be reconfigured.
Dec 08, 2010 | Linksys WRT120N Router
How do you reset the password for my WRT100
There is a small reset button on the back side of the router, where you connect the cables.
Press it and hold it down for 30 seconds. You will need a pen or paper clip.
Release the reset button and wait for 1 minute. Make sure that the power light willl be solid on the router.
Once the power is solid and steady, unplug the power cable of the router. wait for 5 seconds and plug it back in.
When you reset the router, it will come back to the factory default settings and you will need to set up the router again.
Click here for step by step instructions to set up the router.
Aug 11, 2010 | Linksys RangePlus WRT100 Wireless Router
Need to reset Belkin N wireless router
well, to reset the router press and hold the reset button on the back of the box for 10-15 seconds.
Mar 07, 2010 | Belkin N1 Vision Wireless Router
NetGear Range Max wireless router encrypted and needs reset
If you need to reset the router you will find a reset button on the back part of it a small hole that is labeled reset , You just need to press and hold it for about 10 seconds while the power is ON using a pen and then after that unplug the power of the router and that's you the router is already reset and you just need to reconfigure it back..
Sep 03, 2009 | NetGear RangeMax WPN824 Router
Forgot my belkin router password is there a way to reset it?
here you go, from Belkin's website
Reset the router to factory default Resolution With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings. SummaryThis article describes how to reset the router to factory default More InfoThis article assumes you cannot access the routers web interface.
Jan 26, 2009 | Computers & Internet
Computers & Internet Logo
165 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
