Question about Boating
No reverse gear on 115 hp johnson outboard motor
Motor runs fine foward,but only moves boat very slow in reverse gear.
Posted by Robeert Kociban on
  • william moore
    william moore Oct 14, 2012
    Is this an Electro-hydo lower unit, or will it have straight shift. The difference is the electro will go to forward when the power to it quits.
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
Anonymous
  • 187 Answers
SOURCE: Outboard boat engine shifting problems
Check for a lose or sloppy shift linkage.
Posted on May 14, 2009
Anonymous
  • 86 Answers
SOURCE: we have a 9.5 johnson outboard motor, it works in
I would think that the problem is a worn clutch dog. Drain the gear oil from lower unit. You need to disconnect the shift linkage and pull the lower unit like you would to change the water pump. Then remove waterpump housing and waterpump base. The base will have a seal so you need to be careful and gently and evenly pry the base up until it comes off. Next you need to remove the prop and depending on the year there is a ring screw around the prop shaft that needs removed. Also there is a phillips screw that needs to be removed near the lower gear oil drain plug. That screw holds the shift cradle in place. From here you should be able to slide the drive shaft up and out and the prop shaft should slide out. The clutch dog is the smaller piece in between the two gears that engages fwd and rev. You really should have a mechanic do the work but if you get a book it will help you. Pay very close attention how it comes apart and make sure that you dont mix up the fwd gear with the rev. gear.
Posted on Aug 06, 2009
Anonymous
  • 86 Answers
SOURCE: 2003 yamaha 115 outboard motor that dies when
I would check your fuel lines from the tank all the way to the fuel pump. It seems that you might have a pinched line somewhere. You can also bleed the fuel rail with the schrader valve on the end of the rail. If that wont fix it then you probably have a weak fuel pump.
Posted on Aug 09, 2009
Anonymous
  • 6 Answers
SOURCE: 35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Posted on Aug 22, 2009
Testimonial: "Hi, thank you very much for your help, I will strip the carb down and have a look. Once again, many thanks, I am very greatful"
Ideal adjustment on 1996 115 hp oceanrunner Johnson out board motor
Idle adjustment is done on the left (driver) side of the motor by turning the adjuster on the black cable running to the control box at the console. There are 2 one is tensioned to select the gearing. F - N - R
Sep 16, 2018 | Johnson Boating
1996 70 hp johnson outboard ,,need to know why the motor rise up when I put it in reverse and give a little speed to back up, and when I let off the speed the motor goes back down.
In reverse, the propellor is pulling the motor away from the boat, this is the same direction as the motion you get when you tilt the motor up for transport. Check the motor mount, especially the motor tilt mechanism to make sure nothing is excessively worn, bent or loose. Maybe the latch that's supposed to hold the motor in the run position isn't working right - that could be bad news if it lets the motor drop down while the boat is on the trailer.
Jun 26, 2015 | Boating
115 hp johnson great difficulty to cold start,sometimes it even run the baterry flat but once it started there is no problem in starting again what could the reason for this be or do i just start the...
Hello vcd9,
When You Turn The Key On ,Press It In To Activate The Choke Solenoid And Then Crank At The Same Time,This Should Solve Your Problem, If All Is Fine With The Engine.
Cheers
Gordon
Feb 11, 2013 | Light Outboard Motor Boat Bass Fishing...
93" 115 H V4 Johnson outboard motor will start and idle fine
your carburetors might be dirty blocking flow to the high speed jets causing it to bog down
Jun 29, 2010 | RTO Outboard Motor Bass Fishing Boat Rod...
Mercury 115 problems
This could me that reverse gear is not fully engaged.Adjustment on the cables is needed.Take the cowlings off.With the motor not running,move the throttle/gear selector into forward and reverse.You will see where the cables move in the engine area.Note which way the cable moves the selector when reverse is selected.Do this next bit from inside the boat.Hook up the flusher to the motor and start it.Select reverse.When you hear the grinding,push the selector by hand in the direction of travel.It should engage the gear fully.You will see the adjustment threads on the control cables.Move to suit.Hope this helps
Jul 28, 2009 | Boating
Outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Jan 19, 2009 | Boating
Boating Logo
337 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
