All of a sudden, all inputs on our Toshiba 30HF84 show a picture that is slightly doubled and shaking/vibrating. Any hope for it, or is it now junk?
SOURCE: Picture Jumps/flashes for first 5 minutes
I had the same problem and followed the instructions from Jack and my 57h81 is bak up and running. Thanks Jack. RonD
SOURCE: Slightly slanted screen/picture
your main filter capacitor in power supply has gone defective. just replace it . every thing will be normal. good luck.
SOURCE: Are audio boards still avaiable for toshiba 30hf84
I have a Panasonic with a defective audio output, and found a cheap alternative to an impossible to repair problem.
Mine still had audio if I connected headphones to it, but the speakers would get nothing. I found that a decent set of computer speakers (with sub woofer) worked great, and I could move the speakers to provide awesome stereo. Sub woofer is behind the TV.
I did a quick look and did not see an audio specific board available. Likely, it's part of the main board and not cheap to replace.
I hope you can use my fix. It's actually a better sound now than original.
SOURCE: Can't seem to connect Playstation
ok kepp push on the power button on the ps3 its gonna beep ones then its gonna turn off than turn on again but keep pushing on the button its gonna beep ones then its gonna beep twice remove your fingur when it beep twice but make sure the hdmi connected its gonna ask you on the screen you want it to work with hdmi you gonna enter yes
