How to wire 2 ohm
SOURCE: orion xtr15 to a american leagacy la 660 amp
your only choice is to run the amplifier at a 4 ohm mono load - this will not reult in the amplifier making much power.
Positive on sub to Positive on amp.
Negative on sub to Negative on amp.
This is your only possibility.
Adding a second sub in the same fashion will result in a 2 ohm load, and your amplifier will run at its rated potential.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
SOURCE: wiring h2 2ohm sub
ASSUMING YOU HAVE AN AMP FOR THIS SUB, CONNECT LEFT AND RIGHT JACKS, RED AND WHITE TO BACK OF STEREO RUN TO AMP AND THEN FOR A TWO CHANNEL AMP YOU JUST BRIDGE THE TERMINALS SO LEFT + ON CHANNEL ONE AND RIGHT - CHANNEL TWO
SOURCE: I have a 12 inch ORION HCCA dvc, 4ohm sub. My
Halving the impedance will draw twice the current. You could technically get a 3 Db more power since the peak voltage will remain the same. BUT if the magnet structure is not intended to use that cone design, the magnet difference MAY not give you 2 ohms.
In fact, if the designed magnetic flux were smaller, you could wind up with a 1 ohm speaker.
trying to get that much power is really kind of silly as even 50 watts with efficient speakers will exceed safe levels of sound that will not cause damage to your ears.
As you push an amp up in power, usually distortion will increase as well.
