I found the fuel filter loose in the fuel tank
The fuel line rots apart you need to replace the line pull the old hose out take a new hose cut down about a half inch cutting the line to about 1/3 slide a stiff wire down the hole and out the gas cap slide the hose over the wire and slide it back til the cut back end pops out put the filter on the end and pull it into place cut to size and install on the carb
SOURCE: I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
SOURCE: I have a poulan 305 pro chain saw were do the 2 fuel lines go?
Find your model nuber here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The drawing containing your fuel system is as good as it gets. If you need more help contact PoulanPro.com. HTH
Lou
SOURCE: gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
SOURCE: How to connect the fuel lines for Poulan Model # 1950 Chain Saw
The following link should be very helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
A link to a Poulan model 1950 Type 7 follows (may not be your saw, there are 7 different Types and 2 Woodsharks (LE))
http://www.ordertree.com/modelinfo/PWE/1950-Gas-Saw-Type-7/75.1950-Gas-Saw-Type-7.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
