I heard that I can clean risograph drums with diesel or alcohol. How exactly should I apply it? Should I rub it in with fingers or cloth? Should I soak it overnight using a cloth? Let me know if you have experience with this! - Paloma
SOURCE: Risograph Drum
Try run a hundred copies at slow speed and full density/ pressure.
If that fails get a can of WD40 and spray it under the master, then rub the area with your finger. this will desolve the dryed ink on the drum surface.
Dermot
SOURCE: rp 3100 Drum Problem
after cleaning with alcohol leave drum for a couple of days in dark place nd try again.
