Typically I trim and edge, then mow...then come back and blow. The trimming, edging and blowing is done with the same powerhead. I ALWAYS have an issue with it restarting after it has been off for 30 min. Usually 30+ pulls and then I quit for 15 min and come back to struggle it starting again.
This sounds like classic ignition failure symptoms. while the engine is hot, if there is enough room around the spark plug area pull the spark plug and reconnect the wire and set it against the engine (anything metal). with the spark plug exposed and the metal electrode of the spark plug against the engine, pull the engine over and see if the spark plug fires. if it does not then ignition coil is bad.
TRY STARTING WHEN WARM WITH NO CHOKE OR VERY LITTLE
SOURCE: MT830 Color Convergence (Blue Left - Yellow Right)
take a look here: http://www.extremetech.com/article2/0,1697,1049289,00.asp "... The others, however, have lost portions or all of their blue channels. TI's theory is that the shorter wavelength and higher energy of the blue light apparently causes the organic polarizing material in the LCD to get lightburn much faster. TI showed us a damaged LCD panel that controlled blue light transmission, and there was a large spot in the center that was apparently burned out..."
SOURCE: poetable AC compressor licks in for 10 min
It is probably either the high pressure switch or the frost control. The high temp switch usually trips because the condenser coil is dirty which does not allow it to exhaust heat very well. The frost control will trip if the system gets below 39 degrees on the pipes. This is usually do to low refrigerant or dirty filters. Good Luck!
SOURCE: Ryobi RLT30CES
I also tried this.
Hope this helps
please rate my comments - Thanks
Aky1967
SOURCE: honda em2500 starts, runs 1 minute, quits and will not restart
If the oil level is low it will do this, but I also know this to happen when the oil is very cold (thick) an won't fow back own o the crankcase where the oil sensor is. The slow return results in a low oil level. My solution is to start it, when it dies wait a couple of minutes and retry... after a few starts, the oil will warm up, thus flowing back down faster and it then will run. Another option is to use a thinner oil ie;5-30w.
