SOURCE: 52 inch rca hdtv rear projection
Replace the vertical output IC (DL032) on the deflection board. It is mounted on a heatsink, in the middle of the board. That is usually the culprit on the ITC222 chassis for bowing problems. Also, check the solder connections on the flyback transformer.
SOURCE: 52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
SOURCE: rca 52 inch projection
I had the same problem with the power button blinking 3 times and not coming on. I took this advice and changed the flyback 259296. That did not work. I also took the advice of superman276 and changed the cp150 and my tv works now. Flyback is $60 and the cp150 is $2. I pretty much wasted my money on the flyback.
SOURCE: RCA 52 inch projection tv approximately 10 years
Convergence amplifiers need to be replaced. Professional can do this no problem. Call around for price
SOURCE: RCA projection is having color shadows and blurred picture.
Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
