Convert mp4 to mov?
I need to put some mp4 videos to imovie to edit it, I running windows 7. Can you share me a app that free and fast to do this? Thanks.
Posted by Zasterpol on
Vinho Xie
    Master:
  • Computers & ... Master
  • 708 Answers
Actually, iMovie supports MP4 format. You don't need to convert it. But if you insist in convert MP4 to MOV, you can check this article about how to convert MOV to MP4, with which you can also convert MP4 to MOV. Other solutions to convert between them on Mac have also been mentioned.
Posted on Nov 25, 2021
Michael Lei
    Master:
  • 498 Answers
I know an easy to use MP4 to MOV converter - Leawo Prof. Media. And you can complete this task with simple clicks.
Step 1: Add source MP4 videos
Open the "Convert" tab, then click "Add Video" button or directly drag and drop source MP4 videos for loading into this MP4 to MOV converter.
Step 2: Set output profile
Click the drop-down box next to the "Add Blu-ray/DVD" button. Open "Change > Format > Common Video" group to set MOV Video as output format. Or if you want to get HD MOV videos as output, you could choose "Format > HD Video" to select HD MOV Video as output format.
Note: You could adjust video and audio parameters like video codec, aspect ratio, frame rate, resolution, audio codec, bit rate, channel, sample rate, etc. by clicking the "Edit" option on the drop-down list.
Step 3: Convert MP4 to MOV
Save the output profile settings and return to the main interface of Video Converter Ultimate. Click the big green "Convert" button, set output directory in "Save to" box, and then click the bottom "Convert" button to start converting MP4 to MOV.
For more details, check: How to Convert MP4 to MOV for Playing on QuickTime on PC
Posted on Jul 04, 2019
wendy
    Sergeant:
    Habit-Forming:
  • Computers & ... Expert
  • 172 Answers
You can try leawo video converter which supports to convert video formats between180+ different types of video format. and the basic video editing features will help you crop/trim video size,add watermark, turn 2d video to 3d and so on.
check out this guide https://www.leawo.org/tutorial/how-to-convert-mov-to-mp4-with-free-mov-to-mp4-converter.html
Posted on May 22, 2019
Pikeecan
    New Friend:
  • 3 Answers
Try this mp4 converter, it free to download
Posted on Aug 31, 2012
2 Related Answers
TIANPIS
SOURCE: I need to convert some videos to dvd
Try this:Leawo DVD Ripper, it not free but i have the series number, leave you email plz.
Posted on Aug 10, 2012
m1126
Aiko Wang
  • 73 Answers
SOURCE: DVD to mp4 converter? help plz..
iPhone is not able to play DVD directly. And it supports m4v, mp4 and mov videos with H.264 and MPEG-4 codec. So, rip videos from dvd. If the output video still can't be played on iPhone, you need to make conversion again.
This DVD Ripper can put the two steps into one.
Posted on Aug 27, 2012
tip
Best Conversion to ProRes 422-Convert/Merge Flip Videos to ProRes MOV for FCP on...
The <b>Flip Video</b> is a camcorder for digital video created by Pure Digital Technologies. Variants include the Flip Ultra, the Flip UltraHD, the Flip MinoHD (1hr), the Flip MinoHD (2hrs) and the Flip SlideHD. The great Flip Video camcorders record videos in 640&times;480 resolution at 30 frames per second, using the MPEG-4 ASP video compression. The high definition versions record at 1280 x 720 resolution using H.264 video compression, AAC audio compression and the MP4 file format. <br /><br />However, Flip Video can not edit in iMovie, FCP, FCE etc. How to convert Flip Video to iMovie, FCP, FCE etc for editing Flip Video easily? <br />Now with <b>Aunsoft <a href="http://www.aunsoft.com/video-converter-mac/">Mac Flip Video Converter</a></b>, you can convert Flip Video, Flip HD Video files to Apple ProRes 422 MOV, ProRes 4444 MOV, Apple Intermediate Codec MOV etc with no loss of quality for above uses. At the same time, you can get perfect video/audio synchronization, fast conversion speed and editing your Flip Video by trimming, cropping, merging, adding watermark, effecting and more. <br /><br />Below is the step-by-step guide for you to quickly <b><a href="http://canon-videoconverter.com/2011/06/best-conversion-to-prores-422-convertmerge-flip-videos-to-prores-mov-for-fcp-on-mac/">convert Flip Video to ProRes Codec on Mac</a> (*.mov)</b> for editing in Final Cut Pro. <br /><b>Step1:</b> Download, launch the Aunsoft Flip Video Converter and add your Flip Video files to the program. <br /><b>Step 2. Choose Final Cut Pro-Apple ProRes (*.mov) output format.</b> <br />Click the "Format" option and navigate the mouse cursor to <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format. The Mac Flip Video to FCP Converter will <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Flip Video to Apple FCP ProRes MOV</a></b> with high quality. (<b>Tip:</b> The Apple ProRes (*.mov), DVCPROHD (*.mov), HDV (*.mov) formats under Final Cut Pro output profile are available when your FCP is installed on Mac). <br /><br />Step 3. <b>Merge Flip footage Video files. (optional)</b> <br />Tick the checkbox for "Merge into one file", and the Flip Video to FCP Converter will join and combine the video clips into a single file as output. <br /><br />Step 4. <b>Convert Flip Footage Video to Apple ProRes (*.MOV) for Final Cut Pro</b>. <br />Click the convert button under the preview window, and the Mac Flip Video to FCP Converter will start the conversion from Flip MP4 Video to Apple ProRes MOV for Final Cut. <br /><br />After the conversion, you can easily <b><a href="http://www.aunsoft.com/video-converter-mac/">Import Apple Prores MOV to Final Cut Pro without rendering</a> for editing</b>. <br /><br /><b>Tips:</b> <br />If you would like to edit Flip MP4 Video with FCE/iMovie, Avid, etc, you can convert Flip Video to Mac itself bring format like Apple Intermediate Codec, DV PAL/NTSC, DVCPRO NTSC/PAL, DVCPRO50 PAL/NTSC (*.MOV) for FCE and iMovie, or transcode flip videoS to Avid DNxHD (*.mov) for Avid on Mac.
4answers
Best way to convert m2ts video format to mov format?
MTS and M2TS format is a Sony hd camcorders and Panasonic camcorders format.if you want to edit your video clips by imovie than you have to convert it to imovie suitable format.you can convert it mov format bfor edit.mov format is commonly use and most preferred for imovie.just download a good converter. http://www.aimersoft.com/convert-mts/convert-mts-m2ts-to-mov-mac.html
3answers
Can't upload videos to Imovie
Kodak series cameras capture videos in MOV files. iMovie will only import codecs that it can edit. iMovie can import MP4, DV, Apple Intermediate Codec, H.264, Photo JPEG, Motion JPEG, Apple Animation, and perhaps others. MOV is a multimedia container file, not a codec. It can contain any of the above codecs, but it could contain other codecs that are not editable by iMovie, such as MPEG-1 or MPEG-2 so that sometimes iMovie cannot recognize Kodak videos directly.
please try this video converter, good luck. kodak video to imovie
http://www.kodak-video-converter.com/how-to-importedit-kodak-video-into-imovie-on-mac.html
tip
Convert and Edit Canon VIXIA HF200/HV30/HF R11 to iMovie, iMovie? 09, iMovie? 11
"Vixia HV30 HDV camera help! Mac and iMovie? I cant get my vixia HD30 HDV canon camera to import any video to my iMovie. ive set the video type to HD-1080i-30 but still nothing. any ideas on how to fix this?"
"I cannot get my mac to recognize my new Canon Vixia hf200 video camera. How do I get it to import my videos? I have a mac tiger, 10.4. My imovie is '07. The Canon is HD and connects through USB."
As Canon VIXIA HF series camcorders becoming more and more popular among people, you may have problem of uploading Canon VIXIA HF video to iMovie, or Mac. Because some of Canon VIXIA camcorders cannot be compatible with iMovie, iMovie' 08, iMovie' 09, such as Canon VIXIA HF200, VIXIA HV30, VIXIA HFS100, etc. Or even though Canon VIXIA camcorders can be compatible with iMovie or Mac, but sometimes video off Canon VIXIA series is not recognized by iMovie due to different aspect ratio or video codec.
If you cannot import Canon VIXIA video like Canon VIXIA HV30, VIXIA HF200, VIXIA HF S100, etc to iMovie for editing, you need a powerful Canon VIXIA to iMovie Converter to convert Canon VIXIA AVCHD video to MOV, MP4, DV for iMovie firstly, then you can import them to iMovie to share or edit.
Doremisoft Canon VIXIA to iMovie Converter is designed for Mac users to convert camcorder video like AVCHD MTS/M2TS to MOV, MP4, DV for iMovie and Mac. It also support converting video such as MOD, TOD, MKV, etc to Mac, iPad, iPod, iPhone, PSP, Blackberry, iDVD , FCP, FCE, etc.
But how to transfer Canon VIXIA video to iMovie? Here, quick guide for you to follow to convert Canon AVCHD MTS, M2TS files to iMovie step by step:
Step1: Install and Launch Doremisoft AVCHD Converter for Mac
Step2: Import Canon VIXIA Video
Click "Add File" to input your Canon VIXIA AVCHD MTS files to Mac AVCHD Video Converter. You can upload several videos one time.
Step3: Set Output Video Format for iMovie
Click "Profile" to open the Profile drop-up list to select MOV, MP4 or DV as output video format for iMovie.
Step4: Convert Canon VIXIA Video to iMovie
Click "Start" button to convert Canon VIXIA AVCHD files to iMovie. After conversion finished, you can edit your converted Canon VIXIA videos with iMovie as you like.
Related: How to Get AVCHD MTS/M2TS, MOD Files off HD Camcorder to Mac, iMovie, FCP?
How to Convert and Import Sony HDR Series Video to Mac, iMovie?
on Nov 09, 2010 • Computers & Internet
tip
Convert/Edit Canon FS MOD to Mac iMovie
linkAS a new type of camera--a Flash memory-enabled camera, Canon FS200, FS100, FS300 and other Canon FS series MOD camcorders can quickly record, edit and delete movies from the camera itself.
Take Digital Video Camcorder Canon FS200 as a example, owns SDHC Memory Card, features Ultra-Sleek, Compact and Lightweight Design , Genuine 41x Advanced Zoom, DIGIC DV II Image Processor, Superb Shooting Control--Video Snapshot, Quick Start, Quick Charge, Dual Shot and More, Stunning Digital Photography, 2.7" Widescreen LCD. What's more, You'll be satisfied with its quick response time. In addition, when you review your footage, it will start playing more quickly as well.
Although Canon FS users can enjoy HD videos in a high quality, they are sometime annoyed with its output MOD files that cannot be compatible with Mac Quicktime, iMovie, iPad, iPod, and some popular editing softwares such as Final Cut Pro, Final Cut Express. You know Canon FS Series camcorder like Canon FS100, Canon FS200, Canon FS300 capture video with MOD format and MPEG-2 compression, but common video format on Macs are MOV, ,MP4, DV, H.264, etc. So if you want to share Canon MOD files on Macs with your family and friends, you need to convert Canon FS200 or other Canon FS MOD videos to MOV, MP4, H.264 for Mac. Confused? Don't worry, a remarkable Doremisoft MOD converter for Mac can easily offer you to convert Canon FS MOD files on Mac OS. It can transfer Canon, JVC Panasonic Camorder MOD videos to MOV/MP4/3GP/3G2/M4V/DV/MKV etc. andconvert camcorder MOD files to Mac iMovie,Quicktime, iPad/iPhone/iPod, FCP, FCE, or to other popular players such as PSP, AppleTV, Zune, Blackberry, Cellphones and so forth.
How to convert Canon FS200/FS100/FS300 and other Canon FS series to Mac? The following quick guide for you to transfer MOD files to Mac OS step by step.
Step1: Install and Launch Mac MOD Converter
Step2: Import Canon FS MOD Files to Mac OS
Click "Add Files" to upload MOD Files off Canon FS300/FS200/FS100 camcorder to MOD Converter for Mac, you can add more than one MOD video one time.
Step3: Select Output Video formats for Mac
Press "Profile" button to find a suitable output video format like MOV, MP4, DV, H.264 for Mac iMovie, Quicktime, iPad, iPod, iPhones or FCP, FCE, etc.
Step4: Convert Canon MOD Videos to Mac/Snow Leopard.
Click "Start" to transfer Canon FS MOD files to Mac. After waiting for a few minutes, you can share converted MOD video on Mac Quicktime, iMovie, iPad, etc.
Related: How to Edit MOD files on Mac?
How to Put/Convert JVC, Panasonic, Canon Camcorder Video to Mac, MOD to MP4, MOV, DV on Mac?
on Sep 29, 2010 • Computers & Internet
Importing clips into imovie mac
convert DVD to MP4 and edit DVD clips in iMovie, DVD Ripper for Mac is a fast application to convert DVD to iMovie accepted video formats: MP4, MOV, DV, 3GP.
tip
Kodak Movie Converter for Mac?convert mov to avi, mp4, wmv, mpg
Higosoft Kodak Movie Converter Kodak Movie Converter for Mac is the best video converting program to convert mov video, 1080P HD and 720P mov video generated by Kodak Zi8, Kodak Playsport, Zi6 as well as Easyshare to popular video formats, convert Kodak video to iMovie, FCE editable format mpeg-4 on Mac OS X.
Mac Kodak Movie Converter supports batch converting MOV video form Kodak digital camera and can help edit Kodak movie by trimming, merging, cropping videos, Converting Kodak video on Mac means you can convert mov to avi, wmv, mpg, 3gp, dv,flv,rmvb, mp4, swf and more.
  • Convert mov from Kodak to avi, wmv, mpg, 3gp, dv,flv,rmvb, mp4, swf and more.
  • Convert 1080p. 720p HD MOV to other video formats in HD quality.
  • Convert and transfer Kodak MOV to editing software FCE, FCP, iMovie.
  • Convert Kodak video to portable media devices such as iPod, iPhone,iPad BlackBerry, Apple TV, Creative Zen.
on Aug 24, 2010 • Cameras
tip
Convert MKV Video to MP4, AVI, MOV with MKV Converter for Converting MKV on Mac
How to convert MKV file (.mkv file) with MKV Converter for Mac? Here is the best MKV converter, MKV file converter to easily convert MKV files to MP4, MOV, AVI and other common video formats with fast speed and high quality. It’s really a helpful Mac MKV Converter to convert MKV Videos to iPod, PSP, Apple TV, PS3, Xbox, etc or extract MP3, WAV, WMA, AAC or M4A music file from MKV file to enjoy on various digital players.
MAC / Apple instructions to convert MKV movie to Apple TV/iTunes/iPod and more.
Step 1. Free download MKV Converter for Mac
l. Install and run it
Step 2. Add MKV files. This Mac MKV Converter can convert MKV to almost all video format such as MKV to MP4, AVI, MOV, 3GP, DV, 3G2, SWF, MPEG, WMV, FLV, etc.
Note: You can load two or more MKV files or foler using this MKV file converter.
Step 3. Set Output.
Click Profile drop-down to choose files you want to convert video format.
You can reset video parameters and audio parameters etc.
Choose MP4/MPEG-4 movie format for enjoy MKV video on Apple TV/iTunes/iPod, etc.
Choose MOV format for importing MKV on Mac QuickTime, iMovie, FCP, etc
Choose AVI format for Windows Movie Maker, Windows Media Player, etc.
Step 4. Save output folder.
Tips: Before the video conversion, you can edit MKV videos, clip video into small pieces, merge different files into one, add special video effects, etc.
Step 5. Click Start button to convert MKV files to MP4, MOV, AVI, etc video format.
Ok, done.
As the website says it is a professional MKV converter tool designed to transform MKV file (Matroska Video) to various formats HD Quick Time Video, HD MPEG4 Video, HD AVI Video and transfer MKV to SD MP4, AVI, MOV, 3GP, DV, 3G2, SWF, MPEG, WMV, FLV, etc. Doremisoft MKV Converter is just a good Mac Pro like this.
How to import MKV hd into iMovie?
on Jun 17, 2010 • Computers & Internet
Computers & Internet Logo
Ekse
