Question about Panasonic KX TGA270S Cordless Expansion Handset
Panasonic kx tg 271
Registered to a base i don't have
5 Related Answers
martin hogg
  • 157 Answers
SOURCE: DECT registration
Sorry but could you re-confirm the model number, as the post heading shows KX-TG5632 and the text of your query shows it as KX-TG7223E ? ( Panasonic site does not recognise the latter ) Thanks.
Posted on Jan 26, 2008
Anonymous
  • 48 Answers
SOURCE: register hend set to base
Try the procedure on page 62 of the following PDF, and post your results.
http://www.conversationpiece.ie/download/KXTCD505.pdf
Posted on Mar 23, 2009
steve1267
Steve Oakes
  • 233 Answers
SOURCE: no link to base
It sounds like you may be getting interferance from somewhere. Try moving the base unit to another location. Avoid putting by other electronics. T.V.s, microwaves, and such can mess with the signals. Hope this helps Good Luck!
Posted on Jul 24, 2009
Anonymous
SOURCE: I have the kx-tg 4500
I had the same problem once, turned off the base unit from power cord and the phone line and all connected handset units, then turned it back on & it worked.
Posted on Oct 01, 2009
abrinck
abrinck
  • 24 Answers
SOURCE: How to get Panasonic kx-tg 1033 handset to enter lower case
RTFM
Posted on Oct 15, 2009
Testimonial: "This is where I should have started!"
How to register a panasonic a kx-tga850e
Look on the base unit, not the charging cradle. The charging cradle merely plugs into a wall outlet for power. The base unit is the device that's hooked up to the phone line.
Aug 24, 2012 | Panasonic Lands Phones
Hi, suddenly I loss my connection of telephone KX-TG 5632to the base from the handy , I need the way to register it from the base, thanks for your cooperation
1 Handset: {MENU} i {0}{0} 2 Base unit: Press and hold {LOCATOR/ INTERCOM} until the CHARGE indicator flashes. L After the CHARGE indicator starts flashing, the rest of the procedure must be completed within 1 minute. 3 Handset: Press {OK}, then wait until the handset beeps.
Jun 12, 2011 | Panasonic KX-TG5632 Phone
Can I register a panasonic kx-tg55438 handset to a kx-tg5622 base
No, The kx-tg 5622 uses only the kx-tga560 (2 of them) for its cordless sets
Jan 07, 2010 | Panasonic KX-TG5622 Phone
I have the kx-tg 4500 4 line base unit phone. Line one flashes but does not ring or display caller. The other lines work fine. The handsets show no activity ie they don't even flash if a call comes in on...
Aug 05, 2009 | Panasonic KX-TG4500 Phone
Register hend set to base
Mar 23, 2009 | Panasonic KX TCD650E Cordless Phone
Panasonic kx tg7200fx and kx tg 1100 compatible for use in intercom
A few days ago I bought Panasonic KX TG1100 - but the base unit does not ring - only the handset!
Can I do anything about it?
Nov 08, 2008 | Panasonic KX-TG2357 Cordless Phone
Panasonic KX TGA270S Cordless Expansion Handset Logo
65 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
