Yes there is a philips head screw through the centre of the grille and under that there are 2 allen head cap screws. Once they are out you can remove the circular aluminiun disk in the middle. It is sometimes bloody hard to shift after the cap screws are out. Clean everything with scraper and wire brush and assemble. Replace brew head seal while you are there.
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hi
This issue usually occurs due
Daniel
Hi
F2 error in your Asko dishwasher indicates that the water is not draining or is unable to drain and dishwasher not draining issue usually occurs due
Daniel
Hi
Daniel
