Question about NetGear RangeMax WPN824 Router
We lost our password. Wanting to reset the password
We lost our password for our router. We woiuld like to reset it and get a new password
Posted by Melissa Lawson on
Rich Varsay
  • 826 Answers
A forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router. ....read more to reset password
Posted on Aug 31, 2012
Dlink wbr 2310
change the password with a new one (not the default), then change the ssid with a new one (not the default). then reconnect
7helpful
2answers
I lost my net gear n150 cd and i want to change my password..
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
I'm trying to sign into my Netgear Router to reset my password, because I do not remember it and to set-up a secure connection. However whenever I type in http://routerlogin.net, All I get is information...
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.
For routers with a 9-pin manager port on the rear panel: RT314, RT311, RM356, RT328, RT338, RH340, and RH348
See Updating Router Firmware That Uses a Manager Port.
This applies to:
  • All NETGEAR devices
Related articles:
1helpful
3answers
I currently have a belkin wireless g MIMO and want to replace with N1 vision. Will all the set up be lost (password) when I switch to N1 vision. Can I just plug the new one and ready to go? Thanks
Yes, all the setting and password, WEP encryption password, etc WILL BE LOST. Well they are not actually lost, they remain on the old router until you delete them or reset the router to the factory default.
I think what you are really looking for is will the setting and passwords transfer automatically(NO)
So you need to write down the old setting and password if you want to keep them and put them into the new router during set-up.
Unless you are going to personally keep the old router, for security, reset it to clear out the passwords.The reset procedures is the same for both routers
Just in case you do not have the new owners manual here is the direct link to Belkins.
http://cache-www.belkin.com/support/dl/p75490_f5d8232-4_man.pdf
j
I answer these questions for free : a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
Capt. Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Hit reset button on router......wanting to change to my own username and password....now will not work after i thought i applied my settings
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Hi I am lost router Dir-615 password how to do remake new router password Thanks !
Simply reset the router to factory default by pressing reset button on back side of router. Then you can configure it with new setting.
Thanks for joining us. Have a nice day.
2answers
Trying to reset admin password on a Linksys E1000
If you forgot Windows password, you can create a Windows password reset bootable CD/DVD or USB flash drive to reset your lost or forgotten Windows password, i have created a bootable CD with the tool Windows Password Breaker and reset my administrator password successfully.
Lost password to belin router and have a new
To reset your router to default factory settings press in and hold the reset button for about 30sec. Should be on the bottom or the back of the router by the power cord. You should find it.
Lost security key cant connect, box pops up wanting key need to change or get new onenot sure how.
Press the reset button for 30 seconds. This will restore the default settings. The Linksys default user name and password are both "admin" without the quotes. You will have to reconfigure the security settings.
NetGear RangeMax WPN824 Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
