Question about magicJack Plus Pc To Phone Adapter
Plugged the magic jack into computer per instructions. Computer says ethernet cble must be broke, switched cables samething happens. The ethernet plg in on comp. keeps flashing alittle light inside o
The majic J phone worked ok this morning . (first day i tried it.) Came home tonight and a popup came on the comp saying that i had a bad ethernet cord or something else. Changed cords--still no dial tone...
Posted by Keonard Cole on
leagleoh
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
Sounds like the USB port.
Posted on Nov 30, 2014
My magic jack phone stopped ringing and the handset says no line
It sounds like the magic jack is not getting power. Is it plugged into the computer, or a wall outlet? Is the blue light on?
If it is plugged into a computer then unplug the Magic Jack and reboot the computer wait until it reloads and then plug the Magic Jack into a different USB port.
If it is plugged into the wall, Then unplug it for 5 min and then plug it back in.
If it doesn't come up and it is still covered by Magic Jack open up a chat with them at the link here. http://www.magicjack.com/contact.html
Sep 17, 2017 | Lands Phones
Magic Jack Plus worked in USB and then Internet on computer stopped working
It's got the wrong gateway setting. Without a gateway (router) to the Internet it can only see local network stuff. I suspect the Magic Jack is still trying to be the gateway but it has no Internet. Stop Magic Jack doing this and it should work.
Feb 27, 2015 | Computers & Internet
No fail tone my magic jack plus is not connected to a computer, it is going through my router which is plugged into my motem. I have disconnected the power from all devices and then restored power to each...
Without a computer:
1. Plug the magicJack into the power adapter that has been provided
2. Plug the Ethernet cord that has been provided into the magicJack
3. Plug the other end of the Ethernet cord into your modem our router
4. Plug a telephone into the magicJack
5. Plug the power adapter into a power outlet
6. Visit mjreg.com on your computer, tablet or smartphone
IMPORTANT: Your computer, tablet, or smartphone MUST be connected to the same network as the magicJack to be able to register
Item 6 is what you appear not to have done, in order to get dial tone.
Item I
Apr 17, 2014 | magicjack.com Computers & Internet
Magic Jack frequently loses connection even though it should stiil work when offline
To use without computer plug ethernet cord into magicjack otherend into router plug phone in to magicjack plus plug magic jack plus int power adapter plug power adapter into power outlet should work but does not no calls in or out in reverseorder and has to be online with internet conection .
Dec 27, 2013 | magicJack Plus Pc To Phone Adapter
Magicjack doesn't always work right sometimes the phone works , sometimes I get an error 3002 message when I try to call out.
Actiontech what, they many vast models, and routers, and mix.
what are you exact connections here>
NO PC stated, HP model number, this is HP forum. so.....what?
no OS stated, opr. system , windows WHAT?
No modem models stated.
No ISP service stated,
what ISP, what service,? DSL> must I GUESS that?
My guess is not DSL no land line but it is possible to buy DSL
with Landline, disabled, I did for years.
or cable modem, ? uses COAX ! not 2wire twisted like DSL.
or are you doing the MAGIC jack , with NO COMPUTER owned
yes?
The magic jack does not plugin to any modem ethernet port
ever. its usb.
t
Broadband, high-speed internet, cable internet, DSL - WiFi, Fios fiber. and more , dial up? nah you dont have LAND LINE./
error codes,. the first page in the manual states !
Contact your Internet service provider to verify your modem allows more than one device to access the Internet if you receive error 3002 when trying to use MagicJack Plus. Some modems and modem/routers-in-one may not be compatible for use with MagicJack Plus if multiple devices are connected to your network.
We dont know what ISP you have nor the connection type
cable tv modem, DSL, FIOS what?
nor the modem you have , you never said,
this is far more complex
its not magic at all,
fire walls set wrong
ISP blocks you, at your mixed, router and modem
using the routers, USB port is a FAIL.
if you want great help answer what you have and what is connected
in details.
the MAGIC jack as 3 ways to connect,
USB or ethernet.?
Jun 11, 2017 | HP Computers & Internet
Magicjack problems
Hi Frederick,
If you hear error 1 while trying to place a call with your magicJack, it means that you are not connected to the Internet.
To resolve this, make sure that one end of the ethernet cable is plugged into your modem/router/switch and the other end into your magicJack.
You also need to make sure that your modem/router/switch is powered on and that the port you have connected the magicJack to is functioning correctly.
Step 1. if your magic jack plus is plugged directly into computer then be sure to unplug it restart computer then plug the device back in.
Step 2 only if you have it connected to a router and modem first unplug the modem then unplug your router ... leave both unplugged for about 15 seconds then plug in the modem and wait for all the lights to come on then plug in the modem, a lot of times this can solve conectivity issues......
Hope this helps,
Thanks,
Gary
Oct 17, 2013 | Computers & Internet
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
Dec 05, 2009 | NetGear WGR614 Router
We re booted the computer and have to use a usb
Not sure what the problem is, but from what i am reading i am suprised that anything worked at all. A modem jack in your computer is for telephone lines, and the cable modem needs a cat 5 network cable as well as a ethernet card attatched to your computer. ethernet card in your computer cat5 cable runs from the card to the cable modem. Magic jack requires a usb connection as well as a broadband connection to work.
Dec 01, 2009 | Acer Computers & Internet
LinkSYS ADSL2 -AG241Modem + Router Ethernet
First : check your cables if its plugged in securely on each each
port
Second: Try to change their ends
Third : Try to replace your Ethernet cable.
If your router is connected to a modem try to isolate the problem by connecting your router directly to your computer and check f light would turn on. IF YES then thers something wrong with your modem, check it out.
Hope those simple steps ive provided helped you in way, If not pls let me know and lets keep the ball rolling.
Cheers.
Jun 19, 2008 | Linksys ADSL Modem + Router With 4-Port...
magicJack Plus Pc To Phone Adapter Logo
183 people viewed this question
Top magicJack Cell Phones Experts
gaucherre
stargajzer
Are you a magicJack Cell Phone Expert? Answer questions, earn points and help others
