Look up the model, google or the like and see if u can find some schematics. Its does seem likely to be the belt but u may find a better way to crack it open.
not same model number .but on my beko....i had to remove side panel.........remove element cover remove motor fan inside fan opening is 4 small bolts,. remove them..... ,.they hold motor to back plate...on front of machine.remove front fan.....then from side panel..remove plastic motor covering and wire harnes...then the motor just pulls forwards remove back plate...and machine bearing...put new belt on.... manover motor back inti place then refit as you took apart..........
Work on mainly Whirlpool Products did you put the belt on correctly there is probably a belt switch which is closed with a properly installed belt it is under the spring loaded idler pulley or maybe you for got to hook up the door switch hope this helps.
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Tumble Dryer Belts Archives How to Repair Home Appliances
Indesit tumble dryer not turning? How to replace a Indesit tumble dryer belt.
Tumble Dryer Belts from How to Repair Home Appliances
Common faults - 1 Theheating elementscan fail
(meaning open circuit) 2 There arecut-outs (T.O.C's)that
might need resetting 3 Thethermostats (stats)can trip
out or burn out (meaning opencircuit) 4 Moderntumble dryers also have sensors andpcb's (Printed circuitboards)thesehave
programs that can fail and circuitry although most should produce an errorcode
showing you were the fault is. 5 Faultyconnections and burned wires may also be
the fault.
A broken belt is very common. If you hear the motor running, that's probably it. The dryer must be taken all apart to replace the belt. Hopefully instructions will come with the new belt. Routing the belt over the motor shaft and around the tensioner is always a challenge.
It may be too late for you, but here it is. I had the same problem, took the dryer apart, and found that one of the rollers was broken. There are two plastic rollers at the bottom rear of the unit. Call around to local parts stores to see if they have this part. It's easy to fix, just takes all day because you have to completely dissasemble the dryer.
