Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire affinity dryer loc - Frigidaire Affinity ATF7000E Front Load Washer
Electrolux
  • Official Brand Answer
  • 4,342 Answers
LOC is a generic lock code meaning the door was either locked manually or accidentally. Also LOC will lock the control panel and can be manually locked as well. Try to reset the unit for about 10-15 minutes and retry.
Posted on Aug 31, 2012
4 Related Answers
  • 6187 Answers
SOURCE: when i turn on my frigidaire affinity front load
The control lock feature has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. There is a small padlock indicated in the middle of a line between the buttons that toggle the lock on and off. This feature prevents anyone from changing a wash program when in use or a child starting a cycle with the cat or another child in the washer.
The manual for most Frigidaire appliances are available here: http://www.frigidaire.com/manuals . Enter the model number and click Search. Frigidaire lists several models of the Affinity ATF7000E. The direct link to the operating instructions manual for the ATF7000ES0 is here: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134602700ef.pdf . In this manual, the control lock is described on page 2.
I hope this helps.
Posted on Oct 30, 2011
prem mathew
  • 1294 Answers
SOURCE: "Loc" error message
nice
Posted on Mar 20, 2008
Prakash R
  • 1382 Answers
SOURCE: Loc message
Hi, It seems that you have accidentally locked the machine. Hold the "Options" button and the "Select" button simultaneously for 10-15 seconds and your problem will get fixed for sure.
Posted on Apr 12, 2010
Anonymous
SOURCE: Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Posted on Sep 26, 2009
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
How do I unlock it?
Try unplugging, then plug back in.
Jul 31, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Super...
Error loc on frigidaire dryer
The LOC indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Oct 18, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I am trying to use the dryer and an error code of LOC comes on and it won't run
The control is locked. Press and hold the OPTIONS and SELECT button at the same time for 10 seconds or until "LOC" turns off. To lock the control, press and hold OPTIONS and SELECT until "LOC" is displayed. Unplug the machine for at least 30 minutes if pressing and holding the said buttons does not unlock the control to eliminate the possibility of an electronic glitch. The control may need to be replaced if unplugging the dryer still doesn't solve the problem.
Dec 31, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Super...
Loc
It means the control is locked to avoid having someone accidentally start or stop the dryer. Press and hold the Options and Select buttons for 10 seconds or until the “LOC” on the display is cleared. Locking the control is done the same way it is unlocked.
Sep 09, 2010 | Frigidaire Affinity ATF7000ES Front Load...
The LOC flahes on my display, it allows me to pick a cycle but i can not start it. Please help, i tried to press options and select at the same time for the LOC to stop flashing...is there anything else...
"LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. This will fix the issue.
Thank you !!
Jun 19, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please help
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Apr 15, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My dryer says loc and won't run. How do I unlock it?
The door lock has failed. Have it replaced and it should start working again.
Jun 23, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Jun 18, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Dryer affinity code LOC
http://fixitnow.com/wp/2006/04/13/unlocking-the-control-lock-on-certain-electrolux-washers-and-dryers/
Mar 29, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire Affinity ATF7000E Front Load Washer Logo
723 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
