Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
JAMES F FARRIS Posted on Aug 30, 2012
I NEED THE REFERENCE MANUAL FOR C-8080 WIDE ZOOM CAMEDIA
CAN I GET THE CDROM OR DOWN LOAD IT?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Aug 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
350
Points
7
You can download it at http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c8080wz_e.pdf
1helpful
Where can I get a user manual for my Olympus c-5060 wide-zoom camera?
You can download and print the instruction manuals in PDF format by clicking these links:
C-5060 Wide Zoom Basic Manual (11 MB)
C-5060 Wide Zoom Quick Start Guide (811 KB)
C-5060 Wide Zoom Reference Manual (9.6 MB)
Adobe PDF Reader is required to view the manuals. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manuals.
Thanks for using FixYa.
Zoom lever (Olympus Camedia C-8080 Wide Zoom Digital Camera ) does not work
If you can get to the ribbon cable that the zoom lever is attached to, you can use a multimeter or a continuity tester to see if the lever is actually shorting any traces on the ribbon. the zoom lever acts upon a motor that rotates the iner lens barrel, possible the motor lead is open or the switch under the lever is dirty/faulty.
Size filter
The C-8080 will accept standard 58mm filters.
Sound recording and playback
Yes, the camera has a built-in microphone and a built-in speaker.
Connect an flash and aftermarket bracket
When using an external flash with the C-8080 Wide Zoom, you will need the appropriate flash cable with your flash and aftermarket bracket. The Hot Shoe Flash Cable (FL-CB05) mounts to the C-8080 Hot Shoe and the opposite end attaches to the aftermarket flash bracket’s flash shoe or to a standard tripod attachment thread (1/4x20).
Connect an FL-20, FL-36, FL-40 or FL-50 external flash
The FL-20, FL-36, FL-40 or FL-50 external flash can be attached directly to the hot shoe on the camera. You also can use the FL-BK01 Flash Bracket and the FL-CB02 Hot Shoe to TTL cable.
PictBridge
PictBridge is a specification announced by six private companies: Canon, Fuji, HP, Olympus, Seiko Epson and Sony, in December 2002. Its aim is to allow for direct printing between various brands of digital still cameras.
Panorama feature
Yes, the panorama feature is available provided that you use an Olympus brand xD-Picture Card.
IESP auto focus
iESP is the default auto focus setting for the C-8080 Wide Zoom camera. It uses a contrast detecting system to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-8080 Wide Zoom, the AF target mark automatically moves to an area of the image where it finds the optimal contrast.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
