MODEL NO> N51162B 4A
SOURCE: oki c5200 "Fatal Error 106"
from your service manual....main board issue
Posted on Jan 16, 2008
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
SOURCE: oki c9600 fatal error 175
Error 175
Fuser Thermistor
short-circuit or Open
is detected (High
Temperature (HOT)
or Low Temperature
(COLD))
Turn ON power again.
Leave in that state for 30
minutes then turn ON power
again.
Posted on Mar 29, 2010
SOURCE: How do i solve fatal error 980
If you have 980 fatal error and have checked that there is no paper stuck in fuser or you have removed the paper and still have error, then you should contact Oki, there is a fix for this exact problem, if you contact them they will send you a patch which you will need to run on the printer. This will fix your problem
Posted on Mar 02, 2011
Apr 13, 2018 | OKI Office Equipment & Supplies
Jun 20, 2016 | OKI C Office Equipment & Supplies
Jun 02, 2014 | OKI C7300 Led Printer
Apr 26, 2010 | OKI C5650n LED Laser Printer
Jun 19, 2009 | OKI C5150n Led Printer
Apr 16, 2009 | OKI C5200n Laser Printer
Mar 19, 2009 | OKI C5400n Led Printer
Mar 15, 2009 | OKI C5100n Laser Printer
Mar 07, 2008 | OKI C5300n Led Printer
Jan 08, 2008 | OKI C9300 Led Printer
176 people viewed this question
