Question about Canon PowerShot SX130 IS Digital Camera
Instead of downloading the latest photos from camera to computer it downloads all photos previously taken.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Posted on Aug 31, 2012
SOURCE: My computer is not recognising my EOS 20D!
Hi I have exactly the same problem. I'm running Windows Vista Business as the OS and have installed the disk that came with the camera with no avail.
It keeps recognising it as a scanner, but I cannot open the pics. I've tried different cables as well. No use.
Posted on Mar 20, 2008
SOURCE: I cannot download my photos
you dont need the disk. You can just connect your camera to your computers usb port and download your pictures then save it like a normal file.
Posted on Jun 15, 2008
SOURCE: Sony Cyber-Shot DSC-N1 - download photos from camera onto computer
You need to go to MENU, roll down to SET UP
if you roll down you would see at top
"Camera1", "Camera2" and "Memory Stick"
go to Memory Stick and roll down to COPY
go to ALBUM...
and then she ask you...All data in Album will be copied. Ready? touch OK ....
Now you create a folder with all the photos in the memory and you can download it.
I hope this help you...Liz Annette PR
Posted on Jul 09, 2008
SOURCE: Another zoombrowser problem
You can use microsoft scanner and camera wizard to download in the meantime. I'm not sure what is going on with your Zoombrowser software. Which Operating System are you running?
Posted on Jul 16, 2008
SOURCE: Camera Displaying Incompatible JPEG File
Sounds like the card has become corrupted. Did you format it in your camera when you first got it? If not, what you're experiencing eventually happens. Take no more pics until you've recovered any photos that you may be missing, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will need to use a flash card reader with this software. If you don't have one, get one, they're cheap:
http://www.amazon.com/s/ref=sr_st?keywords=card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acard+reader&sort=price
Finally AFTER you've recovered your photos, recommend formatting your card in your camera. Look in the "tools" menu for the selection that shows your card's memory capacity, and select it. Then follow the prompts to format the card. Select "Low Level" format if asked. Note that THIS WILL ERASE YOUR CARD, so again make sure that you have first backed up your photos on your computer.
Posted on Oct 19, 2008
