Question about Kohler 12 kW Emergency Power System - 12RES-L
Problem with kohler 12 kw, showing 38 . 1 code
Posted by Norman price on
Renee F
    Prodigy:
    An expert who has answered 500 questions.
  • Kohler Expert
  • 573 Answers
Normally fault codes are letters? I am not familiar with that code at all. You may have got the control in some configuration setup code 3P0(X) is for raising and lowering the voltage where X is a number from 1-9 for increase
Posted on Nov 22, 2013
1 Related Answer
SOURCE: my 3.5 kw kohler marine
Check that when you run it, it is not in fact making correct voltage (within about 10% is good), also make sure the engine is coming up to full speed, 3600 or 1800. You could check this with a multimeter that measure hertz. On the main output leads when the genset is running make sure it is getting close to 60 hz. or if you are in an area that uses 50 hz. check for that respectively. There are a couple things that would affect this, one would be your SCR module. There is a test procedure for this which you could find here. http://www.scribd.com/doc/50171916/tp6196-1 . I don't work on marine units, mostly standby so these manuals are for residential. Check your fuses, could even go as far as checking the wiring in the back and wiring and condition of the brushes and sliprings. These actually build field voltage to make 240 or 120 volts whatever your unit is configured to make. The brushes need to sit flat on the slip rings and on a unit with 10 hrs. the sliprings I can't imagine would be very dirty but check that as well. If you have an ADC2100 controller use this manual to go into the controller to verify that it is set for the correct voltage that the machine is built to make. The only other fairly simple thing to check that I've had issues with is if Kohler mounted a fuse block on the side of the cabinet mounted to the genset with no vibration isolation. Check these fuses while attempting to run the unit and make sure you getting steady voltage out of them as sometimes they will vibrate causing pulsed voltage to come out of them and can give you an intermittent UU, UF, or OC fault (undervoltage, underfrequency, overcrank).
Posted on Jul 16, 2011
How can I reset the "programmed exercise mode" on my Kohler 12 RES generator
You will likely need to reference your instruction manual for that specific control panel.
Aug 07, 2016 | Kohler 12 kW Emergency Power System -...
Kohler 30RES
Sorry I meant low coolant sensor, not low oil
Nov 29, 2013 | Kohler 12 kW Emergency Power System -...
NoEC code stands for
That means there is no engine code specified in program.
Nov 15, 2012 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
Kohler 12K RES where are links for the installation /setup of the controller? thanks
The 12RESL has no user setup. That's part of lower cost on the DC 2200 controller versus an ADC 2100 or ADC-RES controller that came with the 12 / 17 / 18 RES models. Here is a link for the ADC 2100 Operation / Installtion manual though. http://www.scribd.com/doc/60318571/Kohler-8-5-12RES-Install
Sep 14, 2011 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
When I try to start my generator the code oc comes
Check battery volatge while you are cranking engine if voltage drops below 9 vdc you have a bad battery. If it doesn't you probable have a bad starting solenoid or a bad ground at the starting solenoid.
Nov 11, 2009 | Kohler 12 kW Emergency Power System -...
Kohler 12 kW Emergency Power System - 12RES-L Logo
103 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
