SOURCE: My Toshiba TV won't turn
If none of the controls on the side of the TV or the remote are working, press and hold the power button on the side of the TV for at least 5 seconds to reset the TV. You should then be able to switch it back on.
If you are unable to reset the TV using this method, please can you let me know whether you set the timer recording - either accidentally or deliberately - and whether you have experienced a power outage.
Thanks,
BElectric,
SOURCE: Hi. I have a 42"
The best solution to this problem is to call Toshiba directly and ask for assistance. Any TV repair company/shop will probably charge you an automatic fee to assess the problem, and then tell you it's a very expensive fix. With just the model and serial number of your TV, an easy 5 minutes will get you the answer you are looking for.
SOURCE: i have a toshiba 37 wlt 58 lcd tv . i watched the
Sections of the power supply may have gone out, or it detects short circuits in the backlight inverter board or in the power supply itself.
Those are the two areas you need to check. Look fo bad caps with leaking/bulging top fist in the power supply.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
SOURCE: Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
