HP iPAQ 510 Voice Messenger Smartphone Logo
A
Anonymous Posted on Aug 30, 2012
HP iPAQ 500 Series restor sms - HP iPAQ 510 Voice Messenger Smartphone
1 Related Answer
Anonymous
  • 358 Answers
  • Posted on Jun 17, 2011
SOURCE: I am unable to send
Just Restore factory settings it will get solved. If the problem not solved then call your service provider they will tell you about the settings you just set that settings on your IPaq
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
2helpful
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
3helpful
I am unable to send SMS with my HP ipaq messenger. Though, i am receiving SMS and all other things are working properly. Waiting FixYa
Regards,
Harish
6helpful
How do i do a hard reset on HP ipaq X11-21204?
u have given a wrong Model number this is not a model number infact a part number pls try to find the correct model number from HP site thru photo identification if u dont find ur model other wise i am providing u detail below to try the hard reset on various series of HP IPAQS kindly be sure that ur ALL DATA WILL BE ERASED pls rate me FIXYA if i fixed ur problem
How to Perform a Hard Reset on an HP iPAQ
Performing a hard reset on an HP iPAQ is relatively easy, but is a dramatic step in the management of your handheld organizer. A hard reset will completely clear the memory of your device and restore it to the state you received it in from the factory. A soft reset, on the other hand, simply closes running programs and restarts your pocket PC.
Instructions
Difficulty: Moderately Easy
Step1
Read the owner’s manual. If you don’t have to do a hard reset, you shouldn’t, and you definitely don’t want to do one by accident. So familiarize yourself with the hard reset protocol offered in the manual.
Step2
Make sure you want to clear all personal settings, saved data and personal files from your PDA. If there are files you wish to retain, save them to a removable disk, or send them to your computer’s hard drive to be retrieved at a later date before performing a hard reset.
Step3
For the HP iPAQ h1900 series, hold down the power button while you use your stylus to hold down the reset button (on the left side of the iPAQ). Hold these buttons for a few seconds until the screen fades to black.
Step4
For the HP iPAQ h2000 Series, press down on the far left and right buttons (calendar and iTask, respectively). While you do this, press and hold the reset button on the back of the iPAQ until the screen fades.
Step5
For the HP iPAQ h5000 Series and H3800 Series, the procedure is the same as the h2000 Series with the only difference being on some models the Today button is used instead of the iTask button.
Step6
For the hw6500 Mobile Messenger Series and hx2000 Series the procedure for the hard reset is precisely the same as for the devices in step 4.
Step7
For the rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.
Step8
For the rz1710 and rz1715, follow the same procedure as the devices in step 7, with the difference of pressing the Today button (on the far right) instead of the iTask button.
Step9
To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Tips & Warnings
* If you’re iPAQ is simply slowing down or having problems, try a soft reset (reboot) before resorting to a hard reset.
* Read your iPAQ’s instruction manual to familiarize yourself with how to do a hard reset, and the effects of performing one.
* Do not perform a hard reset unless you are okay with or intend to erase all non-factory installed data and settings from your HP iPAQ.
Cannot send and receive sms, mic is muting
you can hardreset your PAD
i had tried and it's works
2helpful
Hiii
My HP IPAQ HW 6515 dont have voice when in calling position, like a mic muting,but in display mic is not muting, so my destination call cannot hear my voice,but in camera can be record the voice.
My hp ipaq voice messenger 500 series wants to format my storage card on start up
I have the same problem with my hp ipaq voice messenger 500 series wants to format my storage card on start up.
2answers
SMS Inbox Disappeared
Hello Brian, The SMS folder dissapears most probably because another program interferes with it. The same happens on some HP's with camera, where this options dissapears from menu because of some user installed programs. In your case, it doesn't have to be a SMS - messaging related program, there are some compatibility issues and programs that apparently doen't have anything to do with messaging are causing this. You should first try a master reset (hard reset) (save your data first). However in some cases this doesn't help, even if the program that's causing the problem is removed, and you will need a firmware rewrite/update. In order to perform this, or if you don't want to risk performing it yourself please contact me on the live assistance for step by step instuctions. Good luck, Bogdan.
2answers
HP ipaq h6320
Here is a link to the full manual, however it says right in there to not disassemble so you will probably have to find someone's who has done it (maybe on a PDA or Ipaq forum) and ask them for direction. http://user-guides.mobiletopsoft.com/hp/hp-ipaq-h6300-series-user-guide/hp-ipaq-h6300-series-user-guide.php
Vanishing of sms folder.
If after a hard reset the PDA doesn't give you back the sms folder, it is most likely to asume that a ROM reinstall must be done. If you have a USB sync cable, check the HP site and download the ROM version for your Ipaq. Carefull with the rom upgrade, it's a simple process but must be done with care and by the instructions given there.
Top HP Cell Phones Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a HP Cell Phone Expert? Answer questions, earn points and help others
