Question about Archos 605 WiFi Digital Media Player
207 error code
I have code207 error on my Archos 605 wifi 4 GB. How can I solve this problem? Thank you in advance.
Posted by Basak Sa on
  • 6 more comments
  • Basak Sa Aug 30, 2012
    First of all, I really thank you for your solutions.
    I think I should explain in detail;
    When I turn on my Archos 605 wifi 4 GB, I was taken 107 (Recovery) Code,
    So, I have learned that I should download firmware 2.1 and I downloaded
    But it seems firmware does not work. Archos could see firmware file, it was written "File exists", but the file did not worked.
    I selected Format "Disk", "Repair", "No" --> Every solution. But, it did not work. Always there is a white screen And now: I am taking Code 103 Error code.
    After 104, 107 and 207, now it gives 103 error code.
    Reset does not fix the errors, for your information. At last, I think I will try Donaven's solution. Because I am still trying to handle these errors. I have tried every solution.
Wristy
  • 33 Answers
Download the latest firmware for Archos 605 WiFi to your PC.
Connect your 605 to PC and copy the film across and unplug 605 from PC.
I take it you have tried to update it and this happened.
It has happened to others too, they redownloaded and tried again and it worked.
Hope this helps, if it does then reply here please.
Posted on Sep 02, 2012
  • 32 more comments
  • Wristy
    Wristy Sep 02, 2012
    The plugin Donaven is saying about is for unlocking plugin on your device to let it play other formats then the standard that it does when you get it like vob films and such.
  • Wristy
    Wristy Sep 02, 2012
    Also check if your hardrive cable is tight, on the 604 it can work lose and cause problems where you can't format or anything, just the 3 optons.
  • Wristy
    Wristy Sep 02, 2012
    This shows how to open it so you can check the harddrive and how to replace the battery if you ever need to.http://www.youtube.com/watch?v=-mp2g8Xl5...
  • Basak Sa Sep 03, 2012
    Thank you very much Wristaction. I will try and write here the result, later.
  • Basak Sa Sep 04, 2012
    Now, I have finished format (From Archos' screen) and I put the latest firmware which is name is "Archos 605 Wifi (4GB) Firmware 2.1.04 " to Archos' Root, and I safely remove Archos from my computer. Then I close my Archos and after waiting a little, I start my Archos, again....
    After these steps I take the same errors, like an infinity loop.
    Now, I will try to open the case and have a look at hard drive cable...
    Ok, I checked 4GB Archos' cables' thigtheness (With the leading of your youtube video). So, now we know it is not an hard drive problem, at least it is not about cables' thigtheness :) So, what can we do now? What do you suggest, now?
    I will try and try, I will select Format, Repair selections, I will put the firmware to the root, again and again. (I will wait between my steps)... If you will have any other solution , please be informed me, I will be appreciate.
    PS : I always see the white error screen on my Archos.
    When I turn on, I take 104 Error. When I select "Repair", I take "connect your device to your PC and install an update file" and behind this sentence, it is written "done". I am looking My Computer and I can see the firmware is in the root (Actually in System Folder there is a file whisch is name is "mtplib_dirty", I think this comes from Windows 7 (Security, may be), and I delete this file at every time (Because I have read a sentence that says "System folder should be empty for these firmware problems")). Anyway, after I select "done", Error loop starts again...
    One step before taking an error; it is written "update file exists, updating" on screen, and the progress bar completing...
    it is written "update successful" :) Yehuuu :) "press OK to restart" and I am selecting this ...
    :( I take 105 Error.
    Our choices are "No", "Repair Disk", "Format Disk" -- As you see, same error choices :) ...
    When I select "No" to recover the system, it gives nothing. When I select "Repair Disk" and when I open My Computer screen and enter to Archos, I see a file which is name is "Water_Drops.AWF" in System folder, now?
    Should I delete or not this Water_Drop.AWF from the System folder?
    (And I am searching for the firmware file, but it doesn't seems.) Should I put the firmware file to the root in this situation, again?
    I did not delete the Water_Drop.AWF File and I put the latest firmware file (Which I downloaded befor) to the root, again.
    When I select "Repair" choice I meant, for my last comment ... Ok, after a progress bar (Again), I take "Update failed (code 214)" error, and below this sentence, it is written "press OK to restart" and I am restarting...
    Now we take 105 Error, again...Maybe I should select "Format Disk" as a second choice...
    But, at first; I am looking My Computer, again, to look inside of my Archos. And I have seen "mtplib_dirty" is there, again. And I have taken Windows' "Automatically Scan and Fix" / "Scan without fix" like this problem, I select "Scan without fix" (Because when I select "Fix" one, Windows deletes my firmware file which is inside Archos on the root (From my previous experiences ;) ) ) I deleted this "mtplib_dirty" file, and so I update the update file...
    (firmware file that exists). Then it seems Progress Bar, again. And I take "update failed code 207" , So, as it is written on Archos' screen, "Press OK to restart", I select OK.
    And again I take 105 Error Code. (Same as before and same as other error codes it has same choices :) )
    Now, I am formatting (But I know it is hopefullness about to have again and again the same errors)
    But I do not give up and I am trying again and again, like you told me.
  • Wristy
    Wristy Sep 04, 2012
    do a virus scan on it, might be it's got one. Did you redownload the update or use the one you had?
    I don't think that it is about virus scan, but I will scan it. Actually, I downloaded the latest firmware from Archos" Support web site. So, I downloaded that firmware file which is name is "firmware_a605f.aos" and I ised the same file at every time.
    Wristaction, I want to ask you something; When I look my Archos from My Computer, I see Empty Folders ((I think) Because I format Archos) which are names are "Music", "Photos" and "Video", and when I selected "Repair" solution, it is added "System" folder (Windows put the "mtpdirty" and "Water_Drops" files inside this folder) , and at last, there is firmware file which I put to the root, that's all. Is it normal or we should have any other files or folders? Could it because of Reset button, that I use when I see all these errors at first time?
  • Wristy
    Wristy Sep 04, 2012
    Been checking on net and your drive might be dead.
  • Wristy
    Wristy Sep 04, 2012
    Run a scan for bad sectors using windows to see if any bad sectors.
  • Wristy
    Wristy Sep 04, 2012
    With my 604 I had to once delete all the files and then put the update on it and restart it.
  • Wristy
    Wristy Sep 04, 2012
    It then put all the files back again and worked again.
    When I run for scanning from my computer, it says that there is no bad sectors. But for your other solutions, I will try and write results to you. Thank you very much.
5 Related Answers
Anonymous
SOURCE: Archos 605 WiFi stuck
Hey
I suffered the same problem as you, fortunately I fixed it after a lot of messing around.
First what you want to do is switch off the system completely. Once the power light is off, switch the system back on, once the LCD screen turns on, immediately press and hold down the YV/LCD screen for about 5 seconds, a white screen should appear.
You will have three options, click the second option, (i think it is repair) and connect the archos to the PC. This will allow you to transfer all your files to PC because you can access the harddrive.
Once you have taken all the files you want, turn the system off again. Then again, turn the system on, hold down the TV/LCD button for 5 seconds until the white screen appears. Choose the format option. This will take your archos back to factory settings. It took me a few goes to get it back to normal but once its done, you will be glad you put the effort in.
Now all there is to do is to take your files back across via cable and you should be done!
I hope that helped!
Posted on Sep 18, 2008
Anonymous
  • 22 Answers
SOURCE: Archos 605 WiFi "Cannot play video! Please Check"...
Happens to me at least once a week! Use the reset button - works every time.
Posted on Sep 09, 2008
Anonymous
  • 3 Answers
SOURCE: Web Browser Plug-in Archos 605
There is a seller on ebay (name is luhahaca) that says he is an Archos official Plug-ins reseller. Just search for 605 Plug-ins on ebay. He sells a four pack for only $38.00. I bought and installed them and they work great. Really makes the Archos functional - the way it should come out of the box. Actually, (sadly) the way it does seem to come out of the box - I was disappointed when I received my plug-ins download. All 4 plug-ins = 2kb. Web browser with widgets, extended movie and music capabilities and Real player mode. It seems to me that all of this is already in the Archos, they simply charge extra for a key to access it. It's a shame. Totally worth the price if you have an Archos, but really too bad they feel the need to force their hand into your pocket after you've just given them hundreds of dollars. I think the unit would be reviewed better, and Archos wouldn't look so petty, if these features were just enabled right out of the box. (my opinion anyways)
Anyhow, I hope that answered your question!
Posted on Jan 16, 2009
Anonymous
  • 61 Answers
SOURCE: Archos 605 160G Error cod 102
Hi everybody i just got off with archos USA tech support there is no other way but to send it in and they wil replace the HDD with a new one. If the archos is not under warranty repair cost is $ 172.50 i think you can buy another one for that price. Although they give you 90 days warranty for their fix.
Posted on Feb 23, 2009
acharlesc
SOURCE: My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Posted on Aug 17, 2009
3helpful
Hope this helps
3helpful
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
3helpful
My archos 605 has got recovery code 102 and i cant get it to conect to my pc to fix it can u halp
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
Lyrics option in Archos Player
For as long I've got mine, 605 WIFI 160 GB, I don't have such an option for lyrics.
On the PC you can add lyrics in the summary of the music file, but not all
the options from summary appear.
But you mean that you can see the sentence which they are singing at that moment every time?
I don't think that is possible, but try to contact, who knows they can create it soon,
if they change that and add it in new firmware!
HOW TO TURN THE WIFI ON THE ARCHOS 605 160GB
you need to buy the wifi plug in from the archos website, then unload it on to device
Archos 605wifi
I CANNOT GET A PLUG-IN TO WORK, WHEN THE ARCHOS SITE TELLS ME TO DOWNLOAD. IT KEEPS GOING TO A SEARCH LIST.I DONT UNDERSTAND HOW OR WHAT IM LOOKING FOR HELP THANKYOU
3answers
Archos 605 parental code
i got the same problem, somebody help us please?
25helpful
5answers
Recovery code 104
Same issue on my Archos 605 wifi 4GB
The Repair didn't work so here's what I did.
1) connected via USB and got all my Picture, Videos and Music to a safe place.
2) Downloaded firmware update.
fouund it here - http://www.downloadplex.com/Drivers/Firmware/Archos/Download-Archos-605-Wifi-4GB-Firmware-2.1.04_109044.html
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
Archos 605 wifi 30 gb
ave got same prob mate tried to download the firmware as red on the archos site in questions and answers fairly helpful but my computer does not put the archos on my desktop for me to transfer the files rang archos in holand apperently it means it is faulty and i am n the process of sending mine back advise you o rinng them on the 02 n0. that came with the item goodluck
Archos 605 WiFi Digital Media Player Logo
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Ngoro
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
