I've got the answers...
Problem: Lens error.
Symptom: Lens will not extend upon power up.
Cause: Lens is impeded while trying to extend.
This is usually caused by one of two circumstances. (1) The user
dropped the camera while the lens was extended causing a mechanical
failure. (2) The lens attempts to extend while in a pouch or pocket
without the user's knowledge. This usually happens when the user is
carrying the camera with the battery in. When/if the REC button or
power button is pressed accidentally, the lens will attempt to extend
but can't. This causes the main drive gears to be damaged.
Solution: Replace the main drive gear assembly. This should only be done by a qualified tech.
If you've experienced this you know exactly what I mean. This should
clear up any notion that the "Lens Gods" have cursed you. Although this
may have appeared to be a mystery, it's always caused by something!
Symptom: Lens extends, makes a few buzzing noises and retracts, resulting in "lens error" message.
Cause: This is caused by damage to the focus lens often by impact, or sand in the mechanism.
Solution:The focus lens gears either need to be replaced or the
assembly completely rebuilt. Again, this should be done by a qualified
tech. It's a very delicate process.
Problem: Aperture unit failure
Symptom: images appear to be washed out, over exposed and often have horizontal lines through them.
Cause:The aperture unit is either stuck, damaged or not receiving
the proper electrical signal to activate. The result is that the
aperture remains open after the picture is taken and CCD is over
exposed.
Solution:Completely rebuild the aperture unit, which requires
complete lens dis-assembly and rebuild. Again, this should be done by a
qualified tech. It's a VERY delicate process.
Additional details in
THIS LINK.
Hope this helps.
As it turned out PCH was only taking random entries to cut down the number of eligible entrants
