I have a Bosch Logixx 8 Washing Machine WAS32466GB/08 which has an F18 fault code. Trying to get the pump cover off but completely jammed, no movement in either direction. A bit of searching tells me I can remove the panels to access the pump unit but I can't see how to - I've found one screw on the pump cover plate which I've taken out but the front bottom panel is still being held in place towards the middle and left end. How can I release it?
How-2Repair's video is fine but generic like most other vid's out there. But it doesn't explain how to remove the lower front panel on the Logixx 8. There is a holding tap to the high left of the pump cover, that can be releast by a screwdriver. Then in theory the panel can be pried loose, but for me, it seemed to require more force than I was willing to put on the some what flimsy panel. Instead, remove the rear cover and you'll have a clear view of the backside of the panel. It should be easy enough to reach the 4 pincer tap's still holding the front panel. Light squeeze and push, and they'll pop right out.
This video will show you how to change the pump washing
machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE
question.
And don't forget to like us on
facebook
SOURCE: How do you remove Pump Cover on Logixx 8 washing machine?
I have a solution.You just keep turning the white knob anticlockwise. Use a pair of pliars to aid the turning keep going clockwise and anticlockwise if it gets stuck. It will rotate. Just opened my one and found a lollipop stick and a collar stiffner. Good Luck.
SOURCE: I need to get the
try another way. remove the heater - it is just held in by a 10mm nut in the centre then prise out with a screwdriver. you can then see into the gap between tub and drum and fish foreign objects out
SOURCE: Have a Maytag mfw9600sq1 washing
when you remove the screws, pull the panel from the bottom toward you down and out.
