Question about Pride Mobility Products Health & Beauty
My sterling diamond scooter keeps cutting out and then goes again
When i go up a hill the scooter cuts out and if you switch off and on it goes
5 Related Answers
gewiz
Rob Hill
  • 1414 Answers
SOURCE: i have an xl8 mobility scooter that keeps cutting
ok, first take the control panel off, ( panel that has the battery power display etc ) take care in doing to make sure you don't pull any wires off,
first check the wiring on the ignition switch, check the speed pot by moving it up and down,
Check the connections to the battery follow the wires from the battery to the Motor controller, normally marked B+, B-, then follow from the motor controller to the motor again checking the connections.
Make sure the freewheel lever stays in position.
Regards
Gewiz
Posted on Oct 19, 2009
Barry Nixon
  • 103 Answers
SOURCE: charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
Posted on Jul 23, 2009
bunnydawg
Roberta Smith
  • 5158 Answers
SOURCE: manual for sterling elite 4 mobility scooter
i haven't been able to locate a manual online however here is the company website http://www.sterlingscooters.co.uk/index.asp email them or call them they may be able to assist you. keep in mind many companies won't offer support for products bought on ebay.
robert
Posted on Sep 08, 2009
Testimonial: "thanks for the answer so quick il phone them tomorrow"
Will
  • 25 Answers
SOURCE: info neede for mobility scooter
http://www.scootamart.com/mobility/mobility-scooters/heavy-duty-8mph-mobility-scooters/sterling-elite-xs-4-mobility-scooter.html
Posted on Oct 02, 2009
Testimonial: "I had given up hope after mailing several company's asking for the number for the scooter, which was met with no answer, then this morning I cam to mai"
gewiz
Rob Hill
  • 1414 Answers
SOURCE: Throttle does not cut off when released. Scooter keeps creeping f
ok, right the throttle lever has moved round slightly,
Look under the throttle lever where it connects to a stem, this stem should have a cross slot on it , you need to undo the throttle lever, two allen bolts inserted in the lever, move the cross head with a screw driver while holding the throttle lever still, you will need to experiment but it quite easy to sort, the cross slot should be nearly centre when looking under the throttle lever.
Hope that makes sense.
Regards
GeWiz.
Posted on Jan 20, 2010
Testimonial: "NICE TO FINALLY HAVE A CLUE AS TO HOW THESE THINGS WORK!!"
I have new batteries on my Pegasus mobility scooter and it still stalls when going up hill.
hi, there is a chance that the reset switch has gone faulty, at worse the controller is drawing more current than it designed for so that may be a fault ready to happen, but let's be positive, the reset switch needs to be checked...
Regards
Rob
Jan 19, 2016 | Pegasus All Terrain Personal Transporter
I have a rascal Lite way six it has new batteries but cuts out going up long hills.Has the motor got a thermal cut out. If I wait about 10 mins it starts going again.
hi, it could be battery power , are the new batteries now full charge ? there can be a thermal cutout on the controller mosfets getting tooo hot , and that can be faulty...
Questions to ask yourself, your weight , scooter capacity, condition of charger if batteries are new ...
Regards
Rob
www.facebook.com/gewizrepairs
Oct 23, 2014 | Drive Medical Health & Beauty
Pride elite traveler keeps cutting out 9 beeps
it could be the connection between the rear section and the front half. take back section off and see if connection has melted as I have repaired lots with this fault.
Dec 13, 2013 | Pride Mobility Products GoGo Elite...
Scooter cuts out
check the carb float level ,and condition of needle and seat
May 18, 2013 | 1976 Honda CB 100
Mobility scooter
The hill might be to steap and you are tripping the breaker...
Aug 21, 2012 | Drive Medical Odyssey 4 Wheel Full Size...
Have Sterling model RF-45-NG, with Honeywell gas regulator SV9500 that will not start. Getting 6 flashes as code. Fans start, ignitor starts.
Clean flame senser first , try jumping out pressure switch , or try jumping out hi leval cut off or low leval cut off , could be air in gas line .
Sep 02, 2011 | Sterling RF45 Propane Gas Heater (45,000...
The diamond insert in the hub of the blade keeps falling out as soon as I start a cut. What is wrong?
DO NOT USE SAW!!!
1. switch off saw, remove cord from socket (positive electrical insulation)
2. lift table for maximum cut and check size of the washer holding the blade,
3. you should have holding nut with collar, collar is about 1 1/4 (32mm) diameter, then blade (diamond is actually universal reducing bush in some blades) and lastly you should have internal washer, again, about 1 1/4" (32mm) diameter. if your collar are smaller, you need to replace blade as not suitable for your particular model, albeit I am rather suspicious that you have wrong collared nut and internal collar. Please check if both collars are exactly this same diameter. Please check if collars cover diamond cut-out.
4. if you see discreptancy between description in 3, purchase suitable blade (external diameter is 7 1/4" (184mm), as you did not supply what model of your saw, therefore most probably shank is 5/8" (16mm),
5. mount internal bush (collar), will go correctly only in one way.
6. mount blade (pay attention to cut direction, cutting surface should be clockwise if you look at mounting shaft.
7. mount external flared nut
8. check blade for slippage and wobbliness
9. connect power cord and switch on/off
10. check saw blade againg for slippage/wobbliness
11. make test cut if 10 was correct
12. use normally
Do not forget that this is not a toy, it will cut through wood, ocassional nail and your fingers.
Opearating saw crate flying debris, always wear googles or facemask, you have only two eyes and there is no spares.
Please leave note how you go with this advice.
Aug 18, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Celebrity XL4, when going up hill, power cuts out. turn key off and back on, scooter will go again for a couple of feet.
Sounds like Overload Cutout ??? Use a Higher Rating Cutout, as going up hill is very hard on Scooters and it also depends on your weight.
Gerry
Aug 11, 2010 | Pride New Mobility Victory XL 4 Wheel...
Health & Beauty Logo
109 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
