Measuring Tools & Sensors Logo
Posted on Aug 30, 2012
Select a weather station
How to select a good weather station? http://www.familyholder.com/multifunctional-wireless-weather-station-mbo-ws2010.html
  • 1 more comment
  • Anonymous Mar 28, 2014
    Need to restart the rakuten weather station
    I need help to begin setup of this wireless weather station
    How to begin setup
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Aug 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
2425
Points
37
Davis is most reliable even with isolated incidences
Can I download an owners manual for a dr tech WF-1070T outdoor sensor?
Not found it so far but here is a book for a 1050 model, much of which is transferable. There is no Dr. Tech website per se where you can get support or download a manual. That means you would have to depend upon hobbyist/blogs or look up information in generic sites about factors in weather if you have a question. Here is a site where you might try some queries:
http://www.weather-watch.com/smf/index.php?topic=53707.0
http://site.ambientweatherstore.com/Manuals/wh1050.pdf
https://www.rakuten.com/prod/dr-tech-professional-wireless-weather-station-w-solar-transmitter/230818678.html
1helpful
2answers
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Change from 24 hrs to 12 hrs
Instructions
    • 1
      Press the "Power" button to turn the machine on. The device takes approximately 5 to 10 seconds to fully load.
    • 2 Press the "Time" button and hold it down for 8 seconds to begin the setting process for the time. Use the arrows on the left side of the device to select the proper hour and minutes. Use the "Up" button to increase the numbers and use the "Down" button to decrease them.
    • 3 Use the arrows to select the time zone that you are currently in. The device automatically adjusts for daylight savings time. Press the "History" button on the right side of the device to view information regarding past weather history.
Read more : http://www.ehow.com/how_7571640_sharp-wireless-weather-station-instructions.html
I lost my manual on how to setup. How can I setup time and date? It's an ACU-RITE INDOOR/OUTDOOR WEATHER STATION.
I'm not entirely sure on make and model, but this may help :
http://www.ehow.com/how_7762570_acurite-wireless-weather-station-instructions.html
1helpful
Lost my instructions. I replaced the batteries and I can't get it to sinc up.
go to http://www.taylorusa.com/digital-indoor-outdoor-thermometer-1.html and select the link for the manual (Instruction Book under support info, bottom right)
Top Davis Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Davis Measuring Tool and Sensor Expert? Answer questions, earn points and help others
