Question about Janome Sewing Machines
How do I thread a Janome JFS 1817 for double needle function?
Sewing machine JFS 1817
Posted by vosloo_elize on
Debbi's Sewing Machine Repair
  • Janome Master
  • 7,365 Answers
You thread it the same as for a single needle
only you add one more spool of thread & thread thru the same
thread guides as the first needle & then thread the second needle
with the thread from the second spool,
also you have to have a spool holder for the second spool
Posted on Aug 30, 2012
5 Related Answers
Anonymous
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
Anonymous
  • 323 Answers
SOURCE: how to thread sewing machine
Yes, but it is a good basic machine.
Here's how to thread it:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Mar 20, 2009
Anonymous
SOURCE: How to thread sewing machine Janome model 372
how to thread a janome model 372
Posted on Dec 27, 2009
Anonymous
  • 139 Answers
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
http://parts.singerco.com/IPsvcManuals/
Posted on Apr 07, 2010
Anonymous
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
Can I use a twin needle on Janome Sewist 500? I have tried and the threads keep getting tangled, or I get skipped stitches.
Difficult to say. The manual doesn't seem to mention using a double needle. However, frequently, the the bobbin loads from the top or the front, there is a possibility a double needle will work.
Be sure you are using the correct needle and thread for your project. Use a ball-point for knitted fabric. Also, be sure to thread one top thread all the way through the needle and then thread the other thread. Do not thread them at the same time as the threads will twist. If your machine has separators in the thread path for separate threads, be sure to separate the threads. (Most likely your machine does not have separators since there is no mention of using double needles.) ALWAYS THREAD with the presser foot raised.
Janome 525S Instruction Book Changing Needles Needle And Thread Chart
HI WHAT FUNCTIONS DOES THE JANOME JFS 1817 COME WITH. CAN I DO BUTTON HOLES ETC
Even if your machine does not have the buttonhole function, you can still make nice buttonholes with a plain zig-zag machine.
Until Wednesday Calls How To Manual Machine Buttonholes
How to sew buttonhole with an old machine
I have a janome 2049LX. Why doesn't my double needle pick up the bobben thread?
The length of the needle might be too short. Compare the length to your single needles.
Janome 134 sewing machine needle moves while in winding bobbin
sometimes that happens the wheel could be stripped and not tighten all the way it will not hurt your machine just make sure it is not threaded
Instruction manual needed for a Janome Finesse JFS 1817
go to the website of a1sewingmachines.com and call them
about a manual
1helpful
Janome Rx 18S just purchased one second hand online and 1 of the spool pins are broken off. What was the purpose of the 2nd one and where can I find a replacement?
they are only used if your sewing with double needles to hold the
other spool of thread,, most people just buy a thread holder to set
at the back of their sewing machine
here's a link for one for the machine, but a generic spool or cone
holder is just as good,
http://www.sewingmachine-sales.co.uk/twin-needle-spool-pin.htm
The thread skips when sewing with double needle
make sure the needles are inserted all the way up into the needle holder
also the double needles could be damaged
Every 4 or 5 stitches the bobbin thread fails to catch the top thread resulting in skipped stitches
double check needle position and needle type. It will also do this on stretchy material, do to material catching on the thread
Open Questions:
Sewing Machines Logo
Top Janome Sewing Machines Experts
Kolbrun...
Oloyede Monsuru
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
