Question about Invicta Signature Watches
Need battery for 3475 invicta watch
Need battery size
4 Related Answers
Anonymous
SOURCE: Invicta 2875 wrist watch band too large
http://www.geocities.com/watch_crazy/bands/bands.htm
Posted on Jun 30, 2008
escapement
Arturs Kalnins
  • 2338 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
Anonymous
  • 12 Answers
SOURCE: Neeed manual for Invicta 4047 Atomic Watch
The Atomic watches set date & time automatically. The general instruction book applies to the alarm & chronograph features.
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
Posted on Jul 15, 2010
gemineye61
Janelle Schoonover
  • 842 Answers
SOURCE: What battery do I need
I would suggest the following link:
http://www.invictawatch.com/support_files/service_center/ServiceCenter.htm
Posted on Aug 11, 2010
What size battery for mans watch Skagen 355 LSSM ?
why you need size? just look what battery is included - you can buy original or analog battery
Jul 09, 2015 | Skagen Watches
What type of battery fits my watch?
The battery size may be stamped on the back of the watch. Jewelry counters that sell batteries will determine the size and even change it for you. If you are a bit mechanical you can remove the back, mine has little screws but often it is one you pry open with a thin screw driver. You will then see the battery but don't move it until you make note which side is up. The size is stamped on it. Put the new battery in facing the way the old one was and close the cover.
Apr 27, 2015 | Watches
Replacement battery size for ar5303
it battery size 371/370
May 27, 2012 | Watches
What size battery do i need for this watch ?
there are two batteries inside your watch one is for analog sr621 size of battery and the other one is for the digital cr2016 size of battery, i hope this will help you.
Sep 25, 2011 | Fossil Big Tic watch #BG1006 Watch for Men
I have a ladies Citizen Noblia 4420E without a battery and need to know the correct battery #. The diameter appears to be 5.8mm.
Im sorry. Unless it is printed on the back of the watch, or you have the battery, or it is printed in your manual, no one can tell you what size is needed. I will send you a link that you can use to determine what size you need. The best I can do.
http://www.watchbatteries-usa.com/size.html
Best regards.
Aug 23, 2010 | Citizen 47321 Wrist Watch
What size battery do I need for armitron digital sport watch 40-8117 m-690
If the watch #/size is not printed on the back of the watch, you will actually have to remove the battery to figure out what size you need. Best regards.
Aug 21, 2010 | Armitron Compass Bezel Chronograph Sport...
Need battery model number
the size cell that goes in this watch is a 395...good luck :)
May 17, 2009 | Luminox 3102 (Size: ) Watch for Men
Watches Logo
54 people viewed this question
Top Invicta Watches Experts
Bruce Robin
ray gallant
Kardoc
Are you an Invicta Watch Expert? Answer questions, earn points and help others
