I connected my MacBook Pro to the Sylvania TV, via HDMI cable and Dynex adapter. The first time I attempted this the TV turned to static and then a successful connection was made. I have since moved the TV to a different location in my house and have tried connection the MacBook Pro to the TV, via the HDMI and adapter, but unfortunately no connection can be made. The laptop recognizes the TV, but the TV may not recognize the laptop, if that's how it works..? (The TV flashes temporarily before returning to normal after I plug the HDMI cord in, but the TV does nothing, i.e., remains a blank, black screen). I have tried a friend's laptop that runs Windows OS, and it works just fine. Any suggestions?
SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
SOURCE: Blurry picture sylvania ld320ssx LCD TV when connected to ps3
Must change the Signal Tuner board.U well have good video after that.Not than 100% ur LCD Black projection Screen is dead not worth repairing.
SOURCE: sylvania tv not recognizing DVD player
Do one thing press the SCREEN MODE button on the remote repeatedly and check is there is any difference in the screen. If there is no difference then yu tv Have problem wit the T Con board, T con board is on which drives pixels the lcd screen. You can find the T con board of your tv in the following link.
Normally you can find the T con board inside the tv at the bottom center covered by metal cover or aluminum foil. Replacing this board will solve the problem.
http://www.ebay.com/itm/BUF320G04012-T-CON-SYLVANIA-LC320SS8-/140556173476
If you need any more assistance feel free to contact me through fixya
Ajin
