Can not change channel to 60 or 73 for dish
I have my dish box hooked up to hdmi 1 and can not change channel for the dish to come through will not change with any input setting
    Top Expert:
  • 14,553 Answers
Not sure what you mean----if using HDMI the Dish box should change channels. HDMI does not like being hooked up with box and or set on---disconnect set and box including power and wait and hook up and restore power.
Posted on Aug 30, 2012
5 Suggested Answers
Anonymous
  • 33 Answers
SOURCE: No channels?
Try going into the setup menu and make sure the ANT input is set to cable. Then look for Auto Program or Channel Setup and let it scan and find all the channels it can receive. After it's done you should be able to go up and down through the channels.
Posted on Feb 16, 2008
bernardlunda
bernard lunda
  • 318 Answers
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Posted on Apr 30, 2009
Anonymous
  • 74 Answers
SOURCE: Need an Input to hook up Dish network/xbox 360
Sometimes its tricky with those buttons on the front but with most tv's you can get to the menu and change inputs.
One you figure that out you will want to go back in and add that input as a channel in the add/remove channel section then you will be able to get to that input by just changing the channel down below 2
( another way to do this would be to run the auto program with the devices on and see if it adds them that way)
Posted on Sep 18, 2009
yammy_alf
wenceslao alfar
  • 666 Answers
SOURCE: TV changes from input setting to channel 3 when turned on.
you need a service repair, on that ckt there's an IC function as memory IC replace that part and all your program well be stored. can found that ic most likely near switch botton area 4 or 8 pin IC.
Posted on Apr 04, 2010
Chi Chu
  • 8457 Answers
SOURCE: I have a Curtis 24
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Posted on Apr 24, 2011
I have Dish Network with the Hopper. My reviver has a HDMI slot and hooked mt Roku but cannot find how to switch the "input" to what Netflicks. Ugh, been at it for hours!!
Use your TV remote "input" "source" or "tv video" input button. If using the.Dish remote press the clear tv button then input. Repeat to go back to HDMI. Make sure you press sat to change channels once you get back on the HDMI input for dish
Oct 05, 2014 | DISH Network Televison & Video
Dvr 625 from dish
To whom it may concern,
As a technician whom has been in the field for nearly a decade, my suggestion is to contact Dish Network customer service and set up a technician visit.. I know that there are far too many variables that could influence my answer and how I structure it, likely leading to more issues.
Best of wishes,
Dish Guy
If you need further help, I’m available over the phone at https://www.6ya.com/expert/brian_142c5ec89a7a3fda
Feb 13, 2014 | DISH Network DVR-625 DTV Receiver /...
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
What channel does my tv need to be on? and what button do i press on my dish network remote to get me to the wii screen
Usually it depends on how you connected to the TV/satellite box- for instance, I have mine set on channel AUX 1 since I have connected my Wii to the TV using the component cables (the red yellow and white cables) to the port AUX 1. If you've hooked it to the Dish box, then it would be whichever accessory you connected is the channel to select in the dish system, but on the channel that your dish is hooked up (it's situational!)
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Jun 25, 2011 | Nintendo Wii Console
Our new vizio tv is hooked up just like our old tv, (satellite provider being dish network) and it says no signal with a blue screen
Hello. This is usually an easy issue to fix. To get the DISH Network back on the screen, i have included a few steps:
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable, then the TV will need to be on an HDMI input
If you are using Component cables, your TV will need to be on a component input. (Usually Comp 1 or 2)
If you are using RCA cables, then the TV will need to be on a VIDEO input (Usually Video 1 or 2)
If you are using COAX cables, then the tv needs to be on channel 3 or 4 (If you are at TV2, then the TV needs to be on channel 60 or 73)
Becki Barned
DISH Network Customer Service
Feb 26, 2011 | Vizio VX32L Television
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
Xbox and dish network problem
if you have like a dvd player then try hooking the xbox up to it in the front where the video is for the 3 plugs then try to plug dish network in the back of the dvd where the ant in plug is at then take the cord from the dvd player and plug it in the back of the tv if this dont work let me know
Aug 08, 2009 | Microsoft Xbox 360 Console
Screen blanks out int when on local channels
I had the same problem (a flashing HDMI 1 text box in the upper left hand corner of the screen every +/- 10 seconds) and rebooting the cable box seemed to help. I'd previously tried disconnecting and reconnecting the cables, but wasn't successful. I assume my problem originates with Time Warner Cable.
Jan 29, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
