Question about Philips Srp4004/27 Universal 4 In 1 Remote Control Fluorescent Glow Buttons
Sync to my suddenlink box to change the channels
I can not git it to do anything besides turn the tv on and off how do i git it to program to the suddenlink box for a older tv jvc
Posted by courtni91 on
Suddenlink Help
  • 44 Answers
Hi - Tina from Suddenlink here. Please check our help site for instructions on how to program your remote: http://help.suddenlink.com/Television/Pages/RemoteControls.aspx
Posted on Aug 30, 2012
Suddenlink cable remote will turn tv on and off but wont change the channels. is it the remote or the tv?
Try to program the remote again if its universal, if its not then something is wrong with the remote or its in the TV
Feb 11, 2018 | Televison & Video
I have a element tv and I can't get any channels programmed in but ch.3. It is hooked up to suddenlink box.i have tried autoscan and nothing
The suddenlink box transmits on channel 3 and is the only signal being transmitted. When the TV looks for all channels it will only see the one coming into it. This is normal because it is assumed you are controlling channels with the sudden link box, not the TV. If you are using an antennae then you need to go into the TV's setup menu and change the settings from cable to antennae.
Oct 09, 2015 | Element Televison & Video
Blank, snowy screen,cable box on, tv on, volume control on, wont change channel, just snowy screen
have you check your cable? is it connected to your cable box? have you change the channel vhf to uhf?
Apr 06, 2012 | Televison & Video
We have the 27 inch 1080p (Model HSG 1075). We are with Suddenlink as our service provider who recently went to digital programming. However, we are now having problems with the channels display, which...
Hi - My name is Tina and I am with Suddenlink. Are you receiving your channels over the air (without a cable box)? If so, that is the way they are broadcast over the air in digital/high definition from the broadcasters and without converting them (with a cable box) there isn't anything that can be done to fix this issue. If you add a cable box to your set, then the box can convert the channels without the dashes. Plase feel free to contact me directly at tina-AT-suddenlink-DOT-com for further assistance. Thank you.
Jul 25, 2011 | Hannspree HANNSmunich 23" TV
I hooked up my vizio tv to a suddenlink cable box and everytime i change the channel, the channels wont stop changing. Whats wrong?
Hi - My name is Tina and I am with Suddenlink. I'd be happy to help you solve this problem, but need a bit more information. Could you please contact me directly at [email protected]. Thanks!
Mar 22, 2011 | Televison & Video
My orion tv does not see my suddenlink channels
Hi - My name is Tina and I am with Suddenlink. Has your area recently went through the digital switchover? If so, you will need to get a digitalink box to view the channels. Please email me at tina-AT-suddenlink-DOT-com for further assistance. Thank you.
Jan 31, 2011 | Orion Televison & Video
I have the new suddenlink little boxes put on my tv by your people. BUT they did not fix the remotes to work with the tv combos (tv and dvd) They will not turn on the tv therefore I must use one remote...
Hi - My name is Tina and I am with Suddenlink. I am very sorry for the issues you are having with the remotes for your new DigitaLink boxes. If you would email me at tina-AT-suddenlink-DOT-com, I would be happy to help resolve this issue. Thanks!
Oct 13, 2010 | Televison & Video
Tv comes on and can change channels but suddenlink programming is not there. only static on screen
I called suddenlink there is a huge ice storm here and they are out of service. So my problem will be solved when they get back up and running
Jan 29, 2010 | LG RC797T
Is there a reset default setting?
Do you recieve any channels if you run the cable directly from the wall to the TV and do a channel search? You may have to switch your TV over to a different input source if you are using a box. Please email me at tina-AT-suddenlink-DOT-com for more information. Thanks!
Oct 15, 2009 | RCA Televison & Video
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Philips Srp4004/27 Universal 4 In 1 Remote Control Fluorescent Glow Buttons Logo
470 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
