You dont say what you wont but if you click the link below you can download the manual
http://www.timex.ca/en/manuals.aspx
SOURCE: changing the date on a timex perpetual calendar watch
You can download the Perpetual Calendar instructions from Timex's website here.
If you don't like clicking on a link, here's the URL:
http://assets.timex.com/instructions/perpetualCal.pdf
Hope this helps. If this solution has been what you needed, please take a moment to rate it a fixya, and thanks for asking here!
SOURCE: I cannot set the calendar for this watch...can anyone help me?
mcdevito75 here, Your watch (Timex) may have a 2 position stem. Push the stem (winder) all the way in, NOW just lift the stem a little to it:s first position, this should allow the date, (number ) to change, change that number to the date before the date you want, NOW pull the stem out to set the hands, rotate the hands to set proper date and time.
THE WATCH IS SET OUT AS TOP LEFT BUTTON = B
BOTTOM LEFT BUTTON = A
TOP RIGHT BUTTON = C
BOTTOM RIGHT BUTTON = D
10 Half Digit Digital FL145, FL186
Normal Time Display
1. Press A to change mode.
2. Press B for EL.
3. Press C to toggle 12/24 hour format.
4. Press D to stop alarm sound.
Time/Calendar Setting
1. From normal time display, press A three times to enter setting mode. Seconds will begin flashing.
2. Press C to reset seconds to zero.
3. Press D to set and advance to next setting value.
4. Press C to increase digit; press and hold C for fast advance. Press D to set each setting value.
5. Setting sequence is: seconds, hour, minutes, month, date, day of week.
6. Press A to exit setting mode.
Alarm Setting
1. Press A to change to alarm mode (AL).
2. Press and hold C for alarm sound testing.
3. Press C to toggle alarm/chime on/off.
4. Press D to enter setting mode; hour will begin flashing.
5. Press C to advance digit; press and hold C for fast advance.
6. Press D to set hour and minutes.
7. Setting will automatically exit setting mode mode after minutes are set.
Chronograph Mode
1. Press A to change to chronograph mode (ST).
2. Press C to start/stop chronograph.
3. Press D to reset chronograph when it is not running.
Split Time
1. Press D while the chronograph is running.
2. Press D again to return to the chronograph.
3. Press C to finalize timing.
4. Press D to reset to zero.
