Amana RanARG7302 Gas Kitchen Range Logo
A
Anonymous Posted on Aug 29, 2012
Amana ARGS765OE clicking sound no ignition on one burner
1 Related Answer
Anonymous
  • 43501 Answers
  • Posted on Jul 16, 2010
SOURCE: Amana Gas oven does not work.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Amana gas range args7650e makes ticking sound, but does not ignite on one burner
Do not try and lift the top. You will break the gas lines. Use a small nail or pin to clean the hole beside the igniter on that burner that will not light.
https://www.youtube.com/watch?v=ACat1pFqZLY&feature=player_embedded
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Constant clicking sound everything is working fine. How to get the noise to stop
Shut off the power to the range. It sounds like the igniters got wet. If the clicking sound is still there after you put the power back on, light all the burners to dry out the igniters.
5helpful
Clicks but does not does not igite
Hello, thank you for your post. It sound like your saying the burners are not lighting up. Most of the time this is just a simple fix. Next time you turn on your burner notice were the igniter sparks this part of the burner needed to be cleaned. You should be able to take the burner cap off and the burner use a wire brush to clean the surface area so the spark has good contact. Take notice also of the igniter you will need to change it out if you see any cracks around the ceramic housing.
Happy Holidays! Please rate me "4 thumbs" if this information was useful.
The igniter on the left front burner of the
YOU HAVE a shorted ign sw. some of these only came in a wire harnes of 4 . and if they don't change all four when in there .. mm hope this helped .. feed back pls ..
2helpful
Amana gas cooktop clicks when not in use
Take a look at the solutions that have been posted regarding igniters. i suspect a dirty or wet push-down knob. you will see that others have had water/moisture causing problems. drying mights solve it, but it may need a a bit of a clean. keep trying. it must have taken me a couple of hours to solve.
1helpful
I have an Amana AGR5715QDS and when I turn it on and set it for any temperature, lets say 350 degrees, it does not turn on or heat up. The stove top burners still work fine and the door appears to be OK,...
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 05, 2010 • Amana Ovens
1helpful
Lga30aw burner won't stay ignited
The gas valve coils are weak and must be replaced.
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
1helpful
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
Top Amana Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
