I bought 2 hdd external (pqi h567v). i formatted them and then i copy my video files to hdd but i saw this massage every time i wanted to copy windows - delayed write failed. and then automatically disconnect the device. i reconnect my hdd and i should format it again
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or
you might tick one box then return after its finished the first repair then return and tick the second box
you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps
SOURCE: PQI 2G Intelligent Stick
First double check the stick for a tab with a picture of a lock on it, if that is there then switch it to the other position, if your drive lacks the switch then connect the drive. Go to my computer, right click the drive, click properties and search the taps for write protection and disable it(im sorry but i forget what tap it is under) hope that will help you out some but let me know if neither of those help
SOURCE: I have a portable HDD and the model is PQI HDD 551
You have to gently pry it open with a plastic lever - it just like opening an iPod.
SOURCE: windovs uneble to complit yhe format on usb pqi 8
click start control panel
administrive tools computer management device manager scroll down universal
serial bus controllers you should see a yellow question mark?
right click to reinstall
drivers
if you can see your usb
drive but its not working
ports(com&lpt)right
click update driver
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on my
computer you should see your drive
right click then select
format
another way is to control panel administrive tools computer management
disk management right click on your drive select format
hope this helps
SOURCE: My Computer suddenly does not
Check the following
If it wont populate or doesn't show at all in storage manager at all either the drive itself is bad or the control in the external enclosure is bad. You can attempt to remove the drive from the enclosure and plug it in directly into the computer but this tends to void it's warranty. If the drive works however you can simply buy a new enclosure for about $12
Comment back if you need more assistance
Things to try: New USB cable. Format with NTFS. Samller partictions Use only one USB device. This was my problem with an old PC.
i tried but i cant check disk because windows tells me check disk eror
can you see your drive in computer management click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then selectcheck now start or you might tick one box then return after its finished the first repair then return and tick the second box if you cant post a reply with (specific) details on error message
