It stays on for 2 seconds than it shuts down, when i press power key it stays again 2 seconds then it turns off what 2 do ??
SOURCE: on asus support site there is no drivers for Asus
You do not need driver i surpose. The problem exactly is with your video card which does not support this 1440x900 mode. I've saw this problem with internal video cards but on NVidia it
is working perfect. So try to look for updated video card drivers.
SOURCE: Cannot find drevers for Asus VW193D-B 19''
dear Smithbrother,
are you looking your link or not?! There are NO drivers, only manuals.
SOURCE: LCD monitor shuts down every after 2-3 seconds
dustcore025, Need a little more info here. Do you know age of monitor? Was it or did it display a "perfect' image on it the day before? Is it under warranty? How far are you willing to go to try and repair this thing? Do you know how to "part" the snap together plastic back cover from the bezel, after removing the pedestal? This sounds to me like a Switch-mode-power-supply or Inverter problem that occurs when some Electrolytic Filter Capacitors get a little bit TIRED of being constantly subjected to high temperatures near heatsinks that are used to keep semiconductors within operating limits. You can determine how bad this may be if you can do a test and remember what happens. Here is what to do. Make sure PC is fully booted displaying WIN desktop or some other screen. Next, with someone to keep hitting the CTRL or SP bar key every 20-40 seconds while you reconnect both cables of your MM17 back to the PC video port and ac outlet. Now try to turn on the monitor and note exactly what you see and for how long. Did it have a sharp clear image, even for 1-2 seconds? did the screen go black? OK! Next thing is to shine a bright flashlight onto the screen 2 inches away from where you know there was something a few seconds ago. Try it at different angles and not if you see anything. get back to me with results of test. I'm louie12fix on fixya or lmistyrel @ aol.com BYE for now.
no the cable its good when i try with another monitor ex. Samsung syncmaster 720n it works perfectly but with asus it has the same problem 2 seconds on the off
What about the rest? Or even a lower resolution?
i can see the desktop in 2 seconds the brightness is low then the monitor comes black i can see again desktop but very hardly in black
Lower / Higher resolution refers to display settings. Sometimes if its too high the monitor can't handle and it go's black. How about testing the Asus on another PC?
