Question about Toshiba 62HM116
Toshiba 62hm116 blinking yellow lamp light
The yellow lamp LED blinks, and there is now picture or sound. Any suggestions?
5 Suggested Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Toshiba 65HX81 would not show any pictures power light blinking
how many times does it blink?
Posted on Dec 25, 2007
Vista Electronics
  • 1694 Answers
SOURCE: Picture went off then Red light blinks all the time
Not an easy fix....requires chassis pull, careful soldering and
replacement of parts and fuses.....would you like step-by-step?
........................T.
Posted on Feb 01, 2008
Steve Yocum
  • 668 Answers
SOURCE: Blinking yellow light ,no picture or sound.
You have done all you can do. If you had a power outage, when the power came back on a it surged and probably caused a Power Supply problem or something in the micro controller to fail. Either way it 's not good. I would call Toshiba and let them guide you to a Service Facility that can check it out. Depending on your Homeowners Insurance, repairs could be coverd or unit be replaced depending on cost to repair.
Sorry I am not able to help further,
skyassoc
Posted on Jun 23, 2009
Steve Yocum
  • 668 Answers
SOURCE: reset timer toshiba 62hm116
I do not think failing to reset the Lamp Timer would cause the Lamp not to light. You need to get into the Factory Menu while the picture is on in order reset the Timer. I believe you have a Ballast issue either because the Power Supply is not powering the Ballast or the Ballast not Powering the Lamp. In either case, the only way to know is to have a professional to check it out and give a estimate for repair.
I hope this helps,
Skyassoc
Posted on Aug 29, 2009
Anonymous
SOURCE: toshiba 56hm66 yellow light blinks 15 times
unfortunately I don't have any solutions for you. I have just started to have the same problem and have only replaced the lamp. i was going to move on to the ballast but wouldn't want to if it going to be a waste of time. Did you ever find any way to resolve the prolem?
Posted on Dec 06, 2009
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Replaced lamp, sound but no picture
Try unplugging the set for 5 minutes and then replug it in, allow 70 seconds for it to boot up (LED stops blinking). See if it works then. If not press the input/device button and menu button at the same time read a 2 digit code (blinking led) flashes first # short pause and the flashes 2nd #. This will be necissary to determine your cause. Most common besides lamp is power supply caps that cause intermittant operation.
Dec 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony green power/standby led blinks picture goes out
I had this same problem and after doing some research, I removed the lamp, cleaned it and plugged it back in. It fixed my problem completely.
Mar 22, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
No Picture, already replace lamp. model RCA HD50L PW62AYX6
What model set do you have. I also work as a tech at another place that probaly has your troubleshooting guide for your light engine
Jan 17, 2008 | Televison & Video
Toshiba 62HM116 Logo
495 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
