On a Canon MV850i Mini DV Camcorder
SOURCE: software for the canon zr300 mini dv digital camcorder
You will likely have to order this through Canon.
SOURCE: Mini DV tapes transfer to computer
wow, i have the same exact problem. im using a canon too. and i dont have an installation CD or anything, because i baught my camera at a pawn shop. the only thing i can think of is that i might be using the wrong type of fire wire cord? do i need to use a DV fire wire cord? i have no clue.
SOURCE: the card is set for erasure prevention how do i changethat
You can download a user manual here. Your problem, however, does not seem to be related to the camera, but to the SD card. Take the card out and look along the edge for a small 'switch'. This switch will have a 'locked' and an 'unlocked' position. Make sure it is 'unlocked'. If you still get the advisory, try another SD card. (Sometimes those little 'switches' fail.)
SOURCE: I cannot turn off the erasure prevention on my
SOURCE: I have a canon 2000 video camera and it says the
THE CARD IS SET FOR ERASURE PREVENTION
- The LOCK switch on the SD or SDHC memory card is set to prevent accidental erasure. Change the position of
the LOCK switch.
http://shiromundo.blogsome.com
