Question about Birds
In regards to bird cages, why is bar spacing so important? As long as the bird cannot fly out, then why does it really matter?
Posted by cheri pitts on
forrest ranger
    New Friend:
  • 21 Answers
Inappropriate bar spacing can ultimately lead to injuring your bird. A cage where the bar spacing is too large could be hazardous to your bird, while a small distance between spacing will limit your birds view and also your view of your bird.
Posted on Aug 29, 2012
Does the direction of the bars on my bird cage hold any significance?
Yes. The direction (vertical/horizontal) is something worth taking into consideration. Horizontal wires allow your birds to climb, which they thoroughly enjoy. On the other hand, vertical bars are much easier to clean. My personal recommendation is to find a cage where two sides have vertical bars and the others have horizontal ones. This way you are satisfying both the birds and your own time.
Aug 29, 2012 | Birds
What is the recommended bar spacing for a bird cage for doves?
I have found a chart that outlines the appropriate bar spacing for several breeds of birds, hope you find this helpful.
Species
Minimum Cage
Size
Bar Spacing
Finches
18"x30"x18"
1/4" to 1/2"
Canaries
18"x24" x18"
1/4" to 1/2"
Budgies
18"x18"x24"
1/2"
Cockatiels
20"x20"x24"
1/2" to 5/8"
Lovebirds
Parrotlets
24"x24"x24
1/2"
Ringneck Parakeets
24"x24"x36"
1/2" to 5/8"
Conures
Poicephalus
24"x24"x24"
5/8" to 3/4"
Caiques
Pionus
Jardine's
24"x24"x36"
5/8" to 3/4"
Amazons
Mini Macaws
Goffin's Cockatoos
African Greys
24"x36"x48"
3/4" to 1"
Large Cockatoos
36"x48"x48"
1" to 1.5"
Large Macaws
36"x48"x60"
1" to 1.5"
Doves and Pigeons
*see below
1/2" to 5/8"
When it comes to bird cages, why is size so important?
Cage size is a very crucial element in regards to proper bird care. The tail of your bird should never touch the back or bottom of the cage when sitting on their perch. A very general rule to follow is that the width of the cage should be at least 1-1/2 times as wide as your bird's wingspan. Keep in mind that it is not just your bird(s) inhabiting the cage but you will need a perch and most likely some toys. My personal recommendation is to buy the largest cage you can afford.
What size cage should I buy for my budgies?
Even though budgies are quite small, they are very active and need space to fly around and exercise. Budgies need a minimum cage size of 18"x18"x24". Here is a sizing chart that should answer any questions regarding bird species and cage size, along with particular suggested brands of cages to buy.
http://www.bird-supplies.net/size-chart.htm
What's a single bird cage?
The single bird cage comes in a variety of sizes and is suitable for only one bird. Check bar spacing and the width of your bird's wing span to determine the best bird cage fit. Elevate this bird cage to sit at a human's chest level.
Aug 05, 2012 | Birds
What's a playtop birdcage?
The playtop bird cage provides a space for your bird to exercise and explore its freedom outside of the bird cage, and usually includes bird cage feeders as well. A solid top on the playtop bird cage is excellent for collecting food and other bird messes while the bird is on top of the bird cage.
Do I need a Parrot perches?
Parrot perches are usually made for large sized birds. If you own a couple of small birds you don't really need this cage bur if you own more than 3 parrot you should consider a parrot perches to provide your birds the space they need.
Does the size of my cage matters for my birds?
In general, the larger and the more active the bird, the larger the cage one should use. The amount of time the bird will spend in the cage each day is also a factor. A bird that is caged most of the time requires far more space than a bird caged only at night.
Does it matter which cage I'll buy, vertical or horizontal?
Like all things each type has its advantages and disadvantages. Horizontal bars are easier to climb and vertical cages provide better visibility. There are brand which combine the two of them together and you should check out if it's suitable for you.
I have 4 cockatiels, what cage size should I get?
These are beautiful birds! Cage should be 24"x 22" x 30" for one bird - 1/2" to 3/4" bar spacing
May 13, 2012 | Birds
Birds Logo
458 people viewed this question
Top Birds Experts
Kardoc
Tom Chichester
NOEL
NOEL
Are you a Bird Expert? Answer questions, earn points and help others
