Just show any picture of the expantion valve is located
SOURCE: Where is the PCV Valve located on the 1996 4 cyl Cavalier?
the thumbscrew with a hose coming out on the pass. side of your valve cover
SOURCE: 2003 cavalier LS where is the horn located?
it is either located in the middle or on the sides of the steering wheel. usually on both sides.
SOURCE: Where is the IAC valve on a 2003 Cavalier? -
Hello ptrecek: My name is Roger ans I will help you. The idle air control valve or IAC is located on the side of the throttle boby. I have attached o picture that should help. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
